It is currently Sat Oct 24, 2026 8:23 pm
Post Posted: Sat Mar 06, 2010 3:38 pm
hey guys just wondering if anybody had heard much about converting a 2L v6 vitara and putting the 2.5L v6 into it (ive either talked to stekky or steve about this a while ago) did a search around here and found shit all so will start searching the world wide web for the engine and the info
Post Posted: Sat Mar 06, 2010 5:43 pm
I dont know about the wiring side of things but the engine mounts are the same and the 2L gear box bolts straight up or so ive been told :roll:
Post Posted: Sat Mar 06, 2010 10:56 pm
Not many people have done Suzuki v6 conversions on this site..
Post Posted: Sun Mar 07, 2010 12:08 am
There is only two that i have herd about one was for sale on ebay about six months ago and the other was this one
http://www.suzuki4wd.com.au/forum/viewtopic.php?t=2896
Vehicle: suzuki sierra coily
Post Posted: Sun Mar 07, 2010 12:53 am
i helped my brother inlaw put a 2.5l into his 1600 vitara. it was a easy fit considering the inprovment it done to his car. but he a mec and i a auto elec so we had all basis covered.... the ECU wiyh the 2L might be slightly diff perimeters then 2.5L. but i would say if you going to the trouble then go the 2.7L.
Post Posted: Sun Mar 07, 2010 1:16 am
well i think from what i remember in my conversation with who ever it was that the 2.5L will run off the 2L ecu and has the same wiring but the 2.7 needed a differnt ecu and wiring loom
Post Posted: Sun Mar 07, 2010 1:20 am
ahh ok. seams wierd but i saw the diff between a 2L and a 2.5L intake pleneum and there no wonders the 2.5L hooks. do the conversion. go to a wreakes and compare the 2 dash and engine looms and that will give ya an idea...
Post Posted: Sun Mar 07, 2010 1:23 am
g'day all,
was looking for a 2litre for my vitara.so in my travels i got onto a bloke
in adelaide that owns exclusive jap parts,name is rob,said he could fix me
up with a 2.5 to fit straight in,plug an play,complete motor only minus,starter
altenator an air con compresser.the price he quoted me was just under 2 grand
delivered murgon,half hour north of kingaroy.he does them all the time,hope some of this helps.
dan.
Post Posted: Sun Mar 07, 2010 1:24 am
yeah ill have a look at the wreckers and see wat differance there is and the 2l just lacks bottom end power is all and i figure may aswell put the 2.5 in will props cost the same as the 2l to rebuild anyway if not might look into cam regrind
Post Posted: Sun Mar 07, 2010 1:27 am
is the 2 litre still running?
Post Posted: Sun Mar 07, 2010 5:53 pm
H20 & h25 are very similar, "most" of the sensor's are the same, o2's are different, as for pleneum, the intake's are a different size but only the 2.7 has a vacuum operated valve in the intake, hence the need for a different ECU.
H25 should run ok on your ECU but it may need to be tricked into giveing more fuel..
Easy option, buy my car!!!! :roll:
Post Posted: Mon Mar 08, 2010 1:05 am
2L still running but needs a rebuild and stekky i wanna upgrade not down grade
Post Posted: Mon Mar 08, 2010 1:10 am
:roll: Oh well. :roll:
Post Posted: Tue Mar 09, 2010 3:33 am
ive done 2l to 2.5 and 2.5 to 2.7...
treat the engines as a bare long motor and use all the original equipment , including the manifolds .
Post Posted: Tue Mar 09, 2010 3:36 am
Hi!!! :P :P
Want to buy a Gv?? :roll: :lol: :lol:
Cheer's for the alt a couple of months back.. :wink:
Post Posted: Tue Mar 09, 2010 3:44 am
Hi!!! :P :P
nahh sorry mate , vitaras are shit , old school wide tracks are where the good fun is.
i sold you an alternator ? did i do it for a good price ?
Post Posted: Tue Mar 09, 2010 3:45 am
I need a motor,2 or 2.5,have 4 maxxis bighorns on 15x10 alliance mags.
If anyone has one it must be a complete motor ready to plug an play.
Wheels an mags cost me 2.4 thou.Only done sixty k's,like new,because they are.
Post Posted: Tue Mar 09, 2010 4:01 am
you need more than a 2.5 vitara engine to push that buggy along mate . id be looking at a crate engine from the US , big block !!
Post Posted: Tue Mar 09, 2010 4:04 am
I think he got the truck for the rim's. 8O
& yes you did Ok on price, was through work in work hour's, for my car tho.. :P
Post Posted: Tue Mar 09, 2010 4:11 am
They would look meaner on a zook.Thats me ol funhundred,i have put the old 11.5's back on.The 12.5's throw the speedo out buy way too much,gps
helps thou.
Post Posted: Tue Mar 09, 2010 4:14 am
i have a couple of complete or almost complete 2 litre engines , may have a 2.5 would have to check .
Post Posted: Tue Mar 09, 2010 4:20 am
Need complete,running an reasonable k's.
Post Posted: Tue Mar 09, 2010 10:02 pm
losfer,where u located?
Users browsing this forum: No registered users and 246 guests
