It is currently Sat Oct 24, 2026 10:41 pm
Post Posted: Wed Apr 07, 2010 4:25 am
am i correct in assuming that i can run my gti head on a vit bottom end???
just thinking as i want to build a new motor soon.... a bit more power never hurt! and i dont want to go the whole vit motor as it is wired for gti etc...
Post Posted: Wed Apr 07, 2010 4:50 am
I expect it would, to a degree, however how the GTI ECU would go with the extra capacity I'm not sure...
It may underfuel and run lean, and I'm not sure what it would be like in terms of compression compared to the GTI setup...
I'm sure someone here will have a better idea though...
I want my old sig back :(
Post Posted: Wed Apr 07, 2010 9:55 am
can be done, look on redlinegti.com, lotsa conversions like this, it's the motor setup that i will build next :D
Vehicle: '96 LWB trayback
Post Posted: Wed Apr 07, 2010 11:25 am
It's the engine I have in my current zook.
Piss poor really. Not worth the effort.
My last zook had a standard G16b in a swb, it was awesome by comparison.
Now I have g16b + mk1 gti head. aftermarket ecu, extractors, 2" exhaust, enlarged mk3 inlet manifold, 60mm throttle body, sr20 CAS with twin coils running sequential ignition, with a solid fuel system.
Would be a decent engine in a swift, but the combo is total unsuited to offroad work.
The power output is barely above a g16b if you compare dyno results, but the G16b has a better torque curve. I've seen rebuilt g13a engines that make more at the wheels than I do, and my car has had ~30 hours dyno time.
The GTI head doesn't flow sufficient air to make decent power without going to the effort (and expense) of head work. Porting, cam and valve job at a minimum.
Mk2/3 are slightly better in this regard, but still much less flow in standard form than a stock 16v sohc head.
I made decent power when I had the sc14 fitted, but then reliability comes into question.
It usually seems to fall on deaf ears when I offer advice on this topic.
So much of the information on redline/teamswift are from people who have not used the combo, or who go all out with headwork when they build it.
The stock head/block runs, but is not a performance upgrade. It's just an uneccesary complication of an otherwise proven package.
If you're sticking to a suzuki G series engine, go with the standard G16b.
If you follow any build that uses this engine long term, they generally die from underfueling at higher revs.
On top of this, they overfuel on decel and low load, causing worse fuel economy.
- Less fuel economy, no more power, less reliability and a hand grenade waiting to go off. Sounds like a winner to me! :roll:
Post Posted: Wed Apr 07, 2010 2:41 pm
do u happen to know the part number for the mazda dizzy cap used in the gti conversion
Post Posted: Wed Apr 07, 2010 3:30 pm
thanks mate! was just a idea.. i love the durability of the gti motor in mine but wouldn't mind a bit more toque
Post Posted: Wed Apr 07, 2010 3:35 pm
I use a right angle adaptor on mine as it's a SA (mk1).
mk2/3 can use a '86-'89 mazda 323 GT 1.6l Turbo dizzy cap and rotor.
Don't stress about the part number as it isn't standard between manufacturers (several aftermarket suppliers make caps for this vehicle).
Ask for it by model.
Get it from Repco or similar.
Post Posted: Wed Apr 07, 2010 6:59 pm
i did a lot of reading into this and talked to a few that had it and they all say the same thing not worth the hassel and will never run right. They all say stick to the single cam head.
Post Posted: Wed Apr 07, 2010 7:42 pm
Lower gearing
Clearance Hole Technology :P
Post Posted: Wed Apr 07, 2010 8:20 pm
:rofl: :rofl: :rofl:
Maybe you should go re-read the last few weeks of your build thread, cos overheating, leaky sumps and fucked big-ends doesn't sound that durable to me...
Post Posted: Wed Apr 07, 2010 10:23 pm
my mate did this conversion in his hard top it runs great with an after market ecu but not much more power than the 1.6 but one thing it does have is an awsome sound compared to to the 1.6 it sounds amazing but probly not worth the trouble unless u do alotof other things like cams and ajustable cam gears because the timing isnt quite perfect with the belt the fits it would be kool if u want a different engine for no other reason than u wanna be different
Post Posted: Wed Apr 07, 2010 10:27 pm
Spend a few grand on conversion, aftermarket ecu and tuning for a cool sound and for something different. :lol:
You're right about the timing being slightly off. If set to the factory timing marks it will be retarded.
Post Posted: Thu Apr 08, 2010 5:03 am
the Collins Class Submarines are more reliable than that GTI motor
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Post Posted: Thu Apr 08, 2010 4:27 pm
was ment to say drivability...
i think so much of mine is related to luck... its feeling better now tho
Vehicle: jimny
Post Posted: Thu Apr 08, 2010 8:46 pm
luck!!!! jonno i reckon its related to your right foot, yep ive seen all the vids you posted, if in doubt give it some more berries!!!!!
Post Posted: Thu Apr 08, 2010 9:52 pm
posibly mate, but they are a motor that is built to be reved lol... its all good!
Users browsing this forum: Google [Bot] and 295 guests
