It is currently Sun Oct 25, 2026 12:56 am
Post Posted: Sun Apr 11, 2010 1:00 am
so will finally have the engine out tomorrow... just need to get a list of all the seals belts etc i will need to replace anyone know of any I might have forgotten?
[quote="zookieboi"]has anyone really been far even
Post Posted: Sun Apr 11, 2010 1:18 am
A little more detail would be nice. I would start with the fuel cap seal....
Post Posted: Sun Apr 11, 2010 1:30 am
shit sorry rest of my message dissappeared... So I am replacing a G13a with a G13BA I have a new fan belt, spark plugs, oil, oil filter, coolant...
I need to get:
-exhaust manifold gasket and the one going to the exhaust pipe,
-seal for the back of the block where it connects to the gearbox (the o shape one)
-timing belt
-need to inspect the clutch (might as well replace it if its old and the engines already out)
I am also replacing the radiator with a vit one... so need to make up some brackets or something for that...
I just want to make sure I'm not missing anything that could easily be done while the engine is out and that will preserve the life of the replacement one...
Post Posted: Sun Apr 11, 2010 1:35 am
Timing belt tensioner, water pump, rocker cover gasket, all I can think of now
Vehicle: jimny
Post Posted: Sun Apr 11, 2010 1:36 am
31_zook has a write up in rigs section on fitting the vit radiator i think
Post Posted: Sun Apr 11, 2010 1:37 am
peeeete wrote:
-seal for the back of the block where it connects to the gearbox (the o shape one)-timing belt
That o shaped thing is the rear main seal, you will need coolant, oil & filter.
Post Posted: Sun Apr 11, 2010 1:51 am
cheers guys spose i should get a thermostat too...
Post Posted: Sun Apr 11, 2010 2:05 am
Buy as much as you can afford. Look at the condition of the heater hoses at the back of the engine. One of mine failed and it ended up costing me heaps of $$'s just for a $10 hose. Blew a head gasket and in turn replaced a whole lot of shit in the process.
Post Posted: Sun Apr 11, 2010 11:38 am
true... bugger I forgot how much hoses were...
Post Posted: Sun Apr 11, 2010 12:25 pm
if i'm putting the vit radiator on the g13ba which radiator hoses fit?
Post Posted: Sun Apr 11, 2010 8:28 pm
Most probably a combination of the 2, you may have to do some modifications to them to get them to fit properly
Post Posted: Sun Apr 11, 2010 9:03 pm
I used sierra hoses with a vit radiator but I guess vit ones would fit better
do the heater hoses and bypass hoses on the engine while its out, 10mins vs hours that way
if you are doing a cam belt then do the cam and crank seals while you are there
Post Posted: Sun Apr 11, 2010 11:29 pm
i agree, do as much as you can afford it will give you peice of mind
when you are out in the bush. I would replace the clutch with a heavy duty item while your at it.
Post Posted: Tue Apr 13, 2010 12:07 am
anyone know what the difference between VRS and full is?
http://www.suzistore.com.au/shopexd.asp?id=1209
http://www.suzistore.com.au/shopexd.asp?id=124
Post Posted: Tue Apr 13, 2010 12:14 am
VRS basically gives you every gasket you need from the head gasket up. Full set...well, everything. I wouldn't personally buy this one, no offense to them or their product. I just really, really like the 'Monotorque' brand made by ACL. Excellent product. Are you going to bust the head off?? If not just buy the gaskets you need. Garmax international at brendale aren't to bad just for normal inlet/exhaust gaskets etc.
Post Posted: Tue Apr 13, 2010 12:45 am
cool will give them a call tomorrow...
So here is my list so far:
Timing Belt Kit
Manifold Gaskets
Sump Gasket
Thermostat and gasket
Carby Gasket
Fuel Pump Gasket
Rear Main Seal
Crank Seal
Clutch
Hoses (as many as is needed...)
Post Posted: Tue Apr 13, 2010 12:46 am
Pretty well nailed it mate
Post Posted: Tue Apr 13, 2010 1:07 am
sick... just saw this...
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 2759.l1259
and this...
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
and this...
and this...
and and I snapped one of these when taking it out...
just need to find a fuel pump gasket, thermostat and its gasket and a couple of hoses...Still not too sure where to get replacement random lil hoses from though...
Post Posted: Tue Apr 13, 2010 1:20 am
Hoses, suzisport at lawnton, bit dear but he has them. All the gaskets you will want and the thermostat would cost you less than $88 at garmax. They do timing belts also I think
Users browsing this forum: No registered users and 306 guests
