It is currently Sat Oct 24, 2026 2:46 pm
Post Posted: Wed Apr 14, 2010 9:39 pm
In the very near future im going to go to 31's (silverstone extremes), so far im looking at ratio options and how to reinforce the transfer case.
Heres what iv'e come up with, i'd like to know what other people have done or if this setup will work. :?
I plan getting this stuff through LOCKTUP in perth.
Mightykong cradle (not sure if this still uses the stock mounting rubbers and if so is it worth using the bombproof t'case mounts ?)
6.5 's trail creepers (i'm hoping this doesn't lower the high range to much and make it rev to much on highway's)
http://locktup4x4.com.au/suzuki-sierra- ... train-109/
Post Posted: Wed Apr 14, 2010 10:11 pm
i think that 6.5s are to low for 31s on the highway.
there is a gear calc in the tech section, there is enough information in there
Post Posted: Wed Apr 14, 2010 10:18 pm
i have 31 extremes with 6.5s, 3.7 diffs and nt gearbox. 3600rpm at 100kph
which is about standard. i would prefer it to be reving a bit harder. :wink:
Post Posted: Wed Apr 14, 2010 10:36 pm
i am the same as shep..
31s with 6.5 and i do a highway run every day to work.
not revving to hard at all..
any lower and it starts to bog down.
Post Posted: Thu Apr 15, 2010 12:23 am
I hate my reving over 3k, my new truck does 100kph @ 3100rpm, very happy my cam is set for max power around there. Ill never run 6.5 on 31s unless it's a weekend wheeler.
Post Posted: Thu Apr 15, 2010 12:28 am
standard gearing on 31s? i would rather be doing 4000rpm @100kph
Post Posted: Thu Apr 15, 2010 1:21 am
haha, i do about 4200rpm @ 100k. 3.9 diffs, 4.9 transfer on 235s. i do wish i had 31s every day :cry:
Post Posted: Thu Apr 15, 2010 2:51 am
6.5s on 31s all the way
Post Posted: Thu Apr 15, 2010 11:52 am
Stop your bitching.
I run 6.5s and use is at a DD with the stockies on. 4100 rpm at 100 km/h. It runs fine (drove to sydney and back like that). Just man up, and put the 6.5s in.
Xfer case mounts
i keep a few spare of the stock mounts etc. They are cheap to replace, and are the design failure mode. Once you change that, something else more expensive will break.
Post Posted: Thu Apr 15, 2010 12:07 pm
jdk81 wrote:
Stop your bitching.
Xfer case mounts
i am the same, mounts take 2 minutes to change and i only bust around 1 per year.
Post Posted: Thu Apr 15, 2010 12:26 pm
Im also running 6.5's with 31's and they are great on the highway.
Mighty kong is a little extreme too, just run standard mounts, but gusset them. On the long side i welded a length of scrap 20x20 RHS to the bottom, and the other side i just welded a scrap piece of triangle shaped steel on the inside elbow of the mount.
I have never broken a standard rubber mount either.
Post Posted: Thu Apr 15, 2010 12:44 pm
I run 6.5s on 29s revs 200rpm over stock at 100kph.
Benifits are all offroad. :P Then again its not a DD as I haven't run a full tank of fuel throught it on the road in 16 months. :twisted:
I did make my own HD transfer mounts very similar to the mighty kong case. Haven't broken any mounts yet but I drive like "Miss Daisy". :oops:
SS
Post Posted: Fri Apr 16, 2010 2:29 am
jdk81 wrote:
Xfer case mounts
X3 I have mildy bent the long arm but other then that havent had any problems. I now run solid mounts as well without any dramas.
Vehicle: Nissan
Post Posted: Fri Apr 16, 2010 2:42 am
Red89 wrote:
jdk81 wrote:
Xfer case mounts
x4 i made twin mounts on the single side mount and i also made a HD transfer case bash plate as well as strengthened the arms 8)
have a look at my build
http://www.auszookers.com/index.php?nam ... &start=180
Pearce-toff Racing
Users browsing this forum: No registered users and 101 guests
