It is currently Sun Oct 25, 2026 1:01 am
Post Posted: Sun May 02, 2010 11:47 am
ok, i got a 91 sierra with a worn out motor. i just got a complete 98 suzuki cino to do a motor swap. (both carby)
ok ive been on this site doin a search for an hour to know everything i need to know to do the swap b4 i start
i know so far
swap dizzy, sump, oil pick up, water pump (so the fan can bolt up),
do i need to swap the cam?
and everything else i need to know ?
any help would be great
thanx
Post Posted: Sun May 02, 2010 1:05 pm
You may need to swap bottem pully's to, I could be wrong on that tho.
The swift water pump is not made to take the extra load of a fan, that's why you change em.
Post Posted: Mon May 03, 2010 11:27 am
ok cool.ill look that up. thanx
anything else anyone?
Vehicle: jimny
Post Posted: Mon May 03, 2010 11:40 am
i have nothing to add but there are a few of us from the gong so if i can help drop me a pm, cant guaruntee that i will be able to drop past though, busy with work etc...
Vehicle: 92 Suzuki Sierra
Post Posted: Mon May 03, 2010 12:02 pm
Swap the intake manifold& carb ... pretty sure the cino has the themostat on the wrong side
If you want to use the ribbed pulleys on the cino get a vitara waterpump pulley (that way you are set up for power steering or Endless air)
-Santos
Post Posted: Mon May 03, 2010 12:09 pm
u need to swap cam 2
Post Posted: Mon May 03, 2010 12:44 pm
x2 on cam , Cheers Paul.
Post Posted: Wed May 05, 2010 9:16 am
As well as the above , it is easier to use the crank and cam sprockets and timing belt , pullies etc from the old motor , the bottom sprocket on the 98 cino has 5 bolts and must use the 3pk pulleys , the sierra uses a 4 bolt pattern for the 11a0 style belt , if you want the multirib setup , you have to find a vitara water pump pulley that has the 4pk belt setup to use in conjunction with the 3pk setup the cino uses , along with a sierra water pump .
alternatively , you can use the entire 3pk multirib pulley setup , including the cino alternator , and cino water pump , but you will need a thermo fan.
hope this makes sense
Post Posted: Wed May 05, 2010 9:29 am
I have been proven wrong again. :roll:
The internal's of the pump's are the same but the swift has a bugger flange, or hub.
so the pump it's self would easyly take the strain of a fan. :P
I like learning. :P 8)
Post Posted: Thu May 06, 2010 11:58 am
great help guys.
thanx a heap
Users browsing this forum: Google [Bot] and 262 guests
