It is currently Sun Oct 25, 2026 7:58 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
Post Posted: Thu May 13, 2010 6:35 am
MacBear wrote:
gravity_powered wrote:
MacBear wrote:
only use 8L per 100km onroad...
How the hell do you get that kind of milage 8O
Even driving like a grandma 10.5L per 100km is the best I've ever done.
I dont know, when i fill up, i can go 70kms before the fuel gauge even drops, and i can get 150kms on a quarter tank... maybe your ECU on your EFI needs checking or adjusting... or your injectors are a blocked up... i regularly put fuel system cleaner through mine at every 3rd refill... i use a product called " FlashLube ", on the bottle it says it has these benefits -
1) Protects valves and valve seats
2) Increases fuel economy
3) Cleans Injectors and Fuel System
4) Upper cylinder lubricant
5) Reduces emissions
6) Increases engine life
6) Reduces engine temperature
Its about $15 to $20 for a 1 litre bottle, 50mls treats 50 litres, and the GV has a 66 litre tank, so i use 75mls... it works out to be cost effective, and it helps the engine run better.... Oh and another thing, i only fill up with Premium Unleaded, standard unleaded just has to many additives, which makes a dirty engine... :wink: :lol:
Another thing you should know, only run em on 98, anything less is, well, less.
Vehicle: Jeep
Post Posted: Thu May 13, 2010 7:32 am
I wish i could afford to buy 98... dont know about over there, but here in WA, not all stations have 98, and the ones that do, only have one pump out of eight, that has 98... 95 is on just about every pump... and 95 is 10c more than standard unleaded... so i buy what i can afford... mid range... which is better than standard... 95 is $1.32 here, whats it like there ? :wink: :lol:
Vehicle: Suzuki
Post Posted: Thu May 13, 2010 8:07 am
Its about the same, I've found 98 5-8c dearer than 95.
we use flash lube in our commo with gas.
Vehicle: Jeep
Post Posted: Thu May 13, 2010 2:32 pm
Ahhh ok... will have to look into price for 98 here, and where i can get it locally... Yep that FlashLube is good shit for old and new cars ! :wink: :lol:
Post Posted: Fri May 28, 2010 7:52 am
Ok bit of an update, the gv we looked at was a heap of crap..
just also started looking at the XL-7's anyone got any experience of what they're like?
He also likes the x-trails but im not so keen, since theres no low range and theyre front wheel drive
Vehicle: 2004 SQ625 GV
Post Posted: Fri May 28, 2010 7:59 am
A friend at work had an X-trail throw a leg out of bed before hitting 100thou!! All factory services too.
XL7 is just a longer GV but with a few extra gizmo's.
Post Posted: Fri May 28, 2010 8:04 am
Xl7's are the same car but longer, you loose a fair wack of your turning circle in the Xl's but you can live with that if you need the extra room.
Xtrail!!!!! :shocked: :shocked: :shocked: :no:
Please don't, it's a datsun with a Renault eng in it. :evil: :evil:
Vehicle: Jeep
Post Posted: Fri May 28, 2010 2:33 pm
I had a look at an XL7 before i bought my GV, they are very big, longer, wider, and heavier, there are pics of them in the forums going offroad, but i prefer the GV, its smaller, lighter, has a better power to weight ratio, and in my opinion, more capable offroad... :wink: :lol:
Post Posted: Fri May 28, 2010 8:49 pm
Realy????
Post Posted: Fri May 28, 2010 11:56 pm
for XL7 that will be used off road its best to get pre 03 as the later ones can not be lifted more than 50mm.
03 on are allot better inside :roll: so its a hard pick.
Post Posted: Sat May 29, 2010 4:26 am
looking at an 01 model.. seems the air con doesn't work.. they're going to get it regasses and see if that fixes it.. is there any other common air con faults?
Also where is the damn fuse box? lol
Post Posted: Sat May 29, 2010 5:01 am
Compressor's implode, fuse box is under the dash, closer to the kick panel.
The is a main fuse box under the bonnet, please don't ask for the fuel pump relay, I still haven't found it, but there is one, I'm told it's near the heater box. Somewhere. :roll:
Post Posted: Sat May 29, 2010 5:02 am
Driver's side kick panel. :P :P :roll: :wink:
Vehicle: Jeep
Post Posted: Sat May 29, 2010 7:08 am
Realy????
Ha Ha ok you got me, i didnt measure it... not sure if it is, but when i got in it, it felt wider inside, like it had more width, and more room... :roll: so are they wider ?
When i took it for a test drive, it felt like i was towing something, it was so long, and as stated, if you dont allow more room for turning, its very easy to curb it, lol... anyway, i chose the GV, just felt better to me... :wink: :lol:
Post Posted: Sun May 30, 2010 7:24 am
So got the Xl-7 its got a few little niggly things to sort out but was a bargain price..
Has the tensioner rattle on start up for a little bit, whats the best flush and additives to quieten it up?
Also wanna finda bullbar for it, theres no difference between grand vitara and xl-7 bullbars is there?
Vehicle: Jeep
Post Posted: Sun May 30, 2010 7:51 am
Cool... how long does it rattle for, and does it rattle every startup, or just when cold ?
I was told, that tensioner/timing chain rattle, can be a bloody expensive fix 8O almost the price of an engine... or could just be old oil or wrong oil, but other GV owners here can tell you more, as i am still new to the GV :roll:
I have used Nulon Oil flush before, the first time i did it in my old Vit, some of the shit that came out was shocking 8O but after about the third oil change with flush, you can really notice the difference in the old oil when its drained, not even black anymore :wink: :lol:
Post Posted: Sun May 30, 2010 12:08 pm
The outside are the same but i believe that the mounting brackets are slightly different.
I was going to buy an ECB bar second hand that came off an XL7 - i called ECB to check if it would fit....apparently not
Post Posted: Mon May 31, 2010 10:01 am
Think it only rattles when its cold, havent started it too many times since getting home.. will give the oilflush thing a go on the weekend.
Thanks for that shabz, thought we might get lucky and just find a grand vitara one but not the case
Users browsing this forum: Google [Bot] and 100 guests
