It is currently Sun Nov 01, 2026 9:35 am
Post Posted: Thu May 20, 2010 9:57 am
yes are nt diffs and wt diffs the same, can you put nt diff in wt
Vehicle: jimny
Post Posted: Thu May 20, 2010 9:58 am
no they dont bolt in, the centres are the same and that is about it, they also have different ratios 3.7 in NT and 3.9 in WT
Post Posted: Thu May 20, 2010 10:08 am
ER are you sure?
As far as I know, WT and NT diff centres are the same.
I know NT diffs run 4 gear front centres and WT are two gear, but nonetheless the carrier is the same so it's all interchangeable.
Yes NT is 3.9 ratio and WT is 3.7
Post Posted: Thu May 20, 2010 10:10 am
pretty sure eldo said the centers are the same there already, yet you wish to correct him by saying the centers are the same
Vehicle: jimny
Post Posted: Thu May 20, 2010 10:19 am
steve read before posting old mate :D :D
cheers royce
Post Posted: Thu May 20, 2010 11:09 am
ok i was hoping is was a straight swap over
Post Posted: Thu May 20, 2010 11:13 am
so is there away to put a nt diff in wt
Vehicle: jimny
Post Posted: Thu May 20, 2010 11:23 am
you can use the centre, but not the housing or axles etc. are you just looking for a replacement diff? if so it is best to put a complete WT diff in if you can get it or replace the centre with another WT centre. the axles are too short and the hand brake will be different etc etc. most people like myself with a NT want to put WT diffs in at NT spring spacing to allow for more flex, this may be where your confusion is coming from. the only other mod that involves WT diffs and NT parts is to put the NT centres in to lower the diff ratio from 3.7 in a WT to the 3.9's from a NT. i hope this clears it all up for you
Post Posted: Thu May 20, 2010 12:35 pm
I think that steve may have ready the OP's post as 'diff' meaning the entire diff/ axle assembly, not the centre/ 3rd member as intended. In which case steve would be right in what he said.
A little more info from the OP would have avoided this. 8)
Back on topic, yes NT and WT centres are inter-changable.
Pete
Post Posted: Thu May 20, 2010 12:42 pm
the CV's are the same as well :wink: :lol:
Post Posted: Thu May 20, 2010 8:28 pm
If yo can get em off the axle's with out damage. :roll: :P
Vehicle: jimny
Post Posted: Thu May 20, 2010 9:00 pm
to end any confusion the term "no they dont bolt in" refers to the whole complete diff, not the centre
Post Posted: Thu May 20, 2010 9:19 pm
Pete
So in this post you are confirming that he also corrected eldo saying the diffs arent bolt in but the centers are the same,just like eldo said anyway?
you all need more sleep, you are confusing me!
Post Posted: Thu May 20, 2010 10:44 pm
Thats the only reason we come here :wink:
Post Posted: Thu May 20, 2010 11:11 pm
Interchangeable diff centres into a WT Sierra.
1L Later model Maruti's. (4.1)
1.3 Maruti's Front and rear. (4.1?)
1.3 NT Front and rear (3.9) Including Drovers.
1.3 WT Front and rear (3.7)
Rear Coily (3.9) (front will fit but hipinion= more drama's)
Rear Jimny (4.09)
Vitara Front. Various ratios. But alloy casting. Gearset can be swapped into a Sierra or Vitara steel carrier.
Centres that are not interchangable into a WT Sierra.
1L NT Front and Rear
Jimny front
Lj
If your putting a rear diff centre into the front, You will need to change the spider gears for the front axles. Smaller axles mean smaller splines for suzuki's. And visa versa for the rear.
Ratios MUST match front and back.
Post Posted: Fri May 21, 2010 12:06 am
Rear Jimny (4.09)
Jimny front
Lj
If your putting a rear diff centre into the front, You will need to change the spider gears for the front axles. Smaller axles mean smaller splines for suzuki's. And visa versa for the rear. Not if you are running chromos
I wasn't aware that Marutis were available in Australia as a 1.3L? :?
Post Posted: Fri May 21, 2010 12:22 am
X2
Post Posted: Fri May 21, 2010 1:24 am
ok. No 1.3 maruti's then.
I just though i'd clear up the mess that you guys made. 1 hell of a read! Worse then some noobs on ere!
Like i said, bigger the axle, bigger the spline number. i.e Cromo's. But Cromo's are not a standard option. Its aftermarket. May as well say a rear locker will fit in the front with front spider gears etc or chromo's. But that wasnt the main question!
Post Posted: Fri May 21, 2010 1:50 am
How did we get so far off topic? I blame Eldo :lol:
Vehicle: jimny
Post Posted: Fri May 21, 2010 2:39 am
we should call it buttercup!!
Post Posted: Tue Sep 14, 2010 10:20 am
So what year maruti 1l centers will fit wt ? Will my 90 model ones fit ?
My Maruti build, Click WWW
Users browsing this forum: No registered users and 57 guests
