It is currently Tue Jul 28, 2026 1:51 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
Post Posted: Fri May 21, 2010 9:00 am
Hey guys how do i undo the crankshaft bolt on my sierra we have tried impact gun, jarring the head of the bolt with a hammer, have tried jarring the bolt with a spanner and hammer and have also wound the motor over with a long break over bar and nothing has moved. Heating the bolt is a last option :rambo:
Any advise would be greatly appreciated
Thanks Trent
1990 Sierra, 31s and a work in progress
Post Posted: Fri May 21, 2010 9:03 am
what size rattle gun did you use? i needed a big one which we bought from supercheap for like 70$ the size up from what comes with the normal supercheap one. not the best quality but very rarely used so does the trick
Post Posted: Fri May 21, 2010 9:09 am
Don't known Dad uses it when he was working as a machanic it will snap wheel studs if your not carefull
Post Posted: Fri May 21, 2010 9:11 am
put a scoket and breaker bar on it. position it so it will hit chassis rail and than crank motor.
do a few flicks first
give it a good hit with hammer and also spray
Post Posted: Fri May 21, 2010 9:12 am
....or crank shaft bolts :wink:
Post Posted: Fri May 21, 2010 9:19 am
this!!!
make sure its done up tight too or youll flog the keyway
Vehicle: MY2019 Jimny
Post Posted: Fri May 21, 2010 11:20 am
this!!!
He said they did this in his first post...
Post Posted: Sat May 22, 2010 12:33 am
Breaker bar on it, go get a long piece of metal pipe. Slot the pipe over the bar for added leverage!
Post Posted: Sat May 22, 2010 12:54 am
I find it hard to believe that you have put a breaker bar from the bolt head to the chassis and cranked the engine over with the key, that is a hell of a lot of torque, enough to snap the bolt head off.
Take the lead out of the coil so it doesnt start, have the end of the bar 5-6 inches off the chassis and then try, watch you don't get your fingers caught.
Post Posted: Sat May 22, 2010 3:03 am
i couldnt get mine off by cranking it with a breaker bar either
i used heat and then a big rattlegun to get it off, still took me 2 weeks of trying shit to get it off. There is heaps of locktite on there
Post Posted: Sat May 22, 2010 4:29 am
On a Civic i had a 2Metre breaker bar..
Engine torque was not enough. 1.6efi..
Post Posted: Sat May 22, 2010 4:36 am
x2, pull the plugs and get 50 odd degrees of run up, might take a few goes but it will get it
you need fast hard hits to undo bolts, applying massive force with large bars and pipes are how bolts snap, then you really are screwed
Post Posted: Sat May 22, 2010 8:49 am
they're a high tensile item are they not? Had a similar problem with a mate's car, it rounded the head rather than snapping it.
Post Posted: Sat May 22, 2010 9:22 am
Well we got it off, took two men and a 2m long breaker bar. Broke an
engine mount just before it came undone. I'll put picks up soon. Was
crazy tight. Just wanna thank Trent & Peter for helping me. :P
Post Posted: Sat May 22, 2010 9:27 am
How were you locking up the eng???
Post Posted: Sat May 22, 2010 9:32 am
That's cos Honda engines run backwards :wink: :lol:
Post Posted: Sat May 22, 2010 9:36 am
Not all!!!! :roll:
Post Posted: Sat May 22, 2010 9:40 am
Not all!!!! :roll:
His Civic does :P
Post Posted: Sat May 22, 2010 9:45 am
Not all!!!! :roll:
His Civic does :P
I'll take your word for it as I don't know what he has.
First time I heard thay go backwards I said " bullshit!"
Didn't I look like more of a dickhead than normal. :P
Post Posted: Sat May 22, 2010 11:40 am
I originally had it in low range, standing on the brake. That didn't work
so we took out spark plug on cylinder no.1 and put rope in the to lock it up.
Post Posted: Sat May 22, 2010 12:16 pm
Why are you undooing the crankshaft bolt anyway, out of interest... I can't think of many reasons to take it out...
I want my old sig back :(
Post Posted: Sat May 22, 2010 12:27 pm
Oil seal maybe? I like that it doesn't have to come off for the timing belt :D
Post Posted: Sat May 22, 2010 12:29 pm
So we can get the crankshaft gear off to replace the oil seal that was leaking
Post Posted: Sat May 22, 2010 12:32 pm
Yep oil seal, and I did the timing belt at the same time.
Post Posted: Sat May 22, 2010 8:47 pm
you dont put it in low range, that makes it easier to turn the driveline, 5th gear high range is the way to go
Post Posted: Sat May 22, 2010 11:45 pm
Not all!!!! :roll:
His Civic does :P
I don't have a civic...
Sold it long ago :P
I was amazed how easy it is to change a timing belt on suzuki engines. So easy!
Post Posted: Sat May 22, 2010 11:49 pm
I was amazed how easy it is to change a timing belt on suzuki engines. So easy I could do it!
I fikst it for ya Timbo...
Post Posted: Sat May 22, 2010 11:51 pm
ThAt's coS mUm sAyS i riDe oN The SmAll bUs coS i'm spEcial!
Post Posted: Sat May 22, 2010 11:57 pm
Mmmm deeze winders is taystee!
Post Posted: Sun May 23, 2010 6:36 am
Anyone else you want to thank ?? :)
Users browsing this forum: No registered users and 312 guests
