| Author |
Message |
simonprice
Joined: Thu Apr 22, 2010 11:30 pm Posts: 103 Location: noosa/tewantin
 Posted: Sat May 29, 2010 12:30 am |
i have a 93 sierra with a calmini 5inch kit
and i was wondering how i can get it to flex more
wat can i do without taking out leafs and drop shackles
lordfury007
Joined: Mon Sep 28, 2009 11:30 pm Posts: 298 Location: Darwin, NT
 Posted: Sat May 29, 2010 12:35 am |
Can i just get this straight.
You want to get more flex without changing your suspension?
The only thing that might help that i can think of, is longer shocks, and that will only help if your shocks are limiting your down travel.
_________________ 1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
royce
 Posted: Sat May 29, 2010 12:42 am |
spray silicone spray on the leaves
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat May 29, 2010 12:48 am |
what sort of tyres are you running?
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat May 29, 2010 1:33 am |
the calmini shocks are shit. i inverted my rears and put commodore shocks on the front.
i also didn't use the shackle reversal stuff and just used extended shackles instead. without the shackle reversal
stuff calmini front springs move the diff heaps forward.
mine also seem to be getting better with use.
i reckon that this is pretty good
simonprice
 Posted: Sat May 29, 2010 8:41 am |
hey shep i am just wondering wat u mean by invertered rear shocks
just wondering if u could send me pictures of under ur car of the suspension set up
Choppy
Joined: Fri Nov 06, 2009 10:30 pm Posts: 1074 Location: sunshinecoast
 Posted: Sat May 29, 2010 9:05 am |
im assuming with the 5" kit you extended your brakelines? if so its proabbly the shocks as already mentioned.
shep
 Posted: Sat May 29, 2010 9:12 am |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Sat May 29, 2010 9:21 am |
I still don't know why tipping the shocks in more at the top is called "inverting"... Puzzles me. Nice rear end flex in any case Shep - you can see the length in those leaves by the shackle angles.
Anyways... how much flex do you think you can add without lowering your spring rate? AFAIK, 5" calmini springs are very stiff and need leaves pulled to get the car to work.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Sat May 29, 2010 9:41 am |
shep's has got another spring added in ontop of what calmini spring packs have
shep
 Posted: Sat May 29, 2010 9:48 am |
Zook_Fan wrote: shep's has got another spring added in ontop of what calmini spring packs have
got 2 extra now
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Sat May 29, 2010 10:25 am |
un-bolt the shackles from the chassis!
_________________ builder of custom road legal zooks......and stuff.
bron5on
Joined: Thu Apr 02, 2009 10:30 pm Posts: 285 Location: Hobart
Vehicle: SJ80
 Posted: Sun May 30, 2010 11:20 am |
I think it's called in-boarding as opposed to inverting which implies turning the shocks upside down.
shep
 Posted: Sun May 30, 2010 11:25 am |
bron5on wrote: I think it's called in-boarding as opposed to inverting which implies turning the shocks upside down.
thats it, i couldn't remember the correct term. although i do run my shocks upside down now as they clear the diff a lot better.
bron5on
Vehicle: SJ80
 Posted: Sun May 30, 2010 11:29 am |
shep wrote: bron5on wrote: I think it's called in-boarding as opposed to inverting which implies turning the shocks upside down. thats it, i couldn't remember the correct term. although i do run my shocks upside down now as they clear the diff a lot better.
Then both terms apply to you shep!
Gwagensteve
 Posted: Sun May 30, 2010 9:15 pm |
shep wrote: thats it, i couldn't remember the correct term. although i do run my shocks upside down now as they clear the diff a lot better.
You do realise that only monotube shocks (Bilstien, Koni gas, a couple of others) work upside down?
shep
 Posted: Sun May 30, 2010 9:23 pm |
Gwagensteve wrote: shep wrote: thats it, i couldn't remember the correct term. although i do run my shocks upside down now as they clear the diff a lot better.  You do realise that only monotube shocks (Bilstien, Koni gas, a couple of others) work upside down? Steve.
you do realise that i drove around for 4 months with no shocks at all and have only put them on
because i am going into town next week and i don't want the hassle of a defect.
Jccck
 Posted: Mon May 31, 2010 4:14 am |
shep wrote: Gwagensteve wrote: shep wrote: thats it, i couldn't remember the correct term. although i do run my shocks upside down now as they clear the diff a lot better.  You do realise that only monotube shocks (Bilstien, Koni gas, a couple of others) work upside down? Steve. you do realise that i drove around for 4 months with no shocks at all and have only put them on because i am going into town next week and i don't want the hassle of a defect.
Like a baus Shep
Im thinking of removing my shocks, or just finding some absolutely stuffed commo+hiace shocks, painting them yellow and throwin them on.. Mine are WAY too stiff
