It is currently Sun Oct 25, 2026 9:10 pm
Post Posted: Sat May 29, 2010 12:30 am
i have a 93 sierra with a calmini 5inch kit
and i was wondering how i can get it to flex more
wat can i do without taking out leafs and drop shackles
Post Posted: Sat May 29, 2010 12:35 am
Can i just get this straight.
You want to get more flex without changing your suspension?
The only thing that might help that i can think of, is longer shocks, and that will only help if your shocks are limiting your down travel.
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Sat May 29, 2010 12:42 am
spray silicone spray on the leaves
Post Posted: Sat May 29, 2010 12:48 am
what sort of tyres are you running?
Post Posted: Sat May 29, 2010 1:33 am
the calmini shocks are shit. i inverted my rears and put commodore shocks on the front.
i also didn't use the shackle reversal stuff and just used extended shackles instead. without the shackle reversal
stuff calmini front springs move the diff heaps forward. :wink:
mine also seem to be getting better with use.
i reckon that this is pretty good :D
Post Posted: Sat May 29, 2010 8:41 am
hey shep i am just wondering wat u mean by invertered rear shocks
just wondering if u could send me pictures of under ur car of the suspension set up
Post Posted: Sat May 29, 2010 9:05 am
im assuming with the 5" kit you extended your brakelines? if so its proabbly the shocks as already mentioned.
Post Posted: Sat May 29, 2010 9:12 am
Post Posted: Sat May 29, 2010 9:21 am
I still don't know why tipping the shocks in more at the top is called "inverting"... Puzzles me. Nice rear end flex in any case Shep - you can see the length in those leaves by the shackle angles.
Anyways... how much flex do you think you can add without lowering your spring rate? AFAIK, 5" calmini springs are very stiff and need leaves pulled to get the car to work.
Post Posted: Sat May 29, 2010 9:41 am
shep's has got another spring added in ontop of what calmini spring packs have
Post Posted: Sat May 29, 2010 9:48 am
got 2 extra now :D
Post Posted: Sat May 29, 2010 10:25 am
un-bolt the shackles from the chassis!
Vehicle: SJ80
Post Posted: Sun May 30, 2010 11:20 am
I think it's called in-boarding as opposed to inverting which implies turning the shocks upside down.
Post Posted: Sun May 30, 2010 11:25 am
thats it, i couldn't remember the correct term. although i do run my shocks upside down now as they clear the diff a lot better. :lol:
Vehicle: SJ80
Post Posted: Sun May 30, 2010 11:29 am
Then both terms apply to you shep! :wink:
Post Posted: Sun May 30, 2010 9:15 pm
You do realise that only monotube shocks (Bilstien, Koni gas, a couple of others) work upside down?
Post Posted: Sun May 30, 2010 9:23 pm
you do realise that i drove around for 4 months with no shocks at all and have only put them on
because i am going into town next week and i don't want the hassle of a defect. :wink:
Post Posted: Mon May 31, 2010 4:14 am
Like a baus Shep
Im thinking of removing my shocks, or just finding some absolutely stuffed commo+hiace shocks, painting them yellow and throwin them on.. Mine are WAY too stiff
Users browsing this forum: No registered users and 164 guests
