It is currently Mon Oct 26, 2026 9:18 am
Post Posted: Mon May 31, 2010 10:39 am
on the weekend the bottom bolt on a rear shock came loose and went and lost itself.
anyways today i took the other one off and tried to find a match but with no luck.
i went to the suzuki wreckers in cannington and they said they went out the back and took a bolt off a jimny and gave it to me for free.
in the picture the top bolt is the one i took off my jimny and the bottom bolt was from the wreckers.
it is a bit shorter but the thread is the same.
do you think i can still use it???
Post Posted: Mon May 31, 2010 10:49 am
pic didnt work
Post Posted: Mon May 31, 2010 10:56 am
mine broke when i put the lift in, i just drilled it out and then kept drilling all the way through and then welded a nut onto the end of a bit of all thread then put another nut on the other side. works perfeclty.
Post Posted: Mon May 31, 2010 11:30 am
will be fine, the longer one has a 'lead-in' to make the assembly process easier.
Vehicle: Currently vehicle-less
Post Posted: Mon May 31, 2010 11:36 am
Yep - one of mine came off a while back and I have that exact other bolt in my rear RHS. Been in there a few months now with no dramas.
Post Posted: Mon May 31, 2010 2:12 pm
i don't even drive with shocks at the moment...
Post Posted: Mon May 31, 2010 9:28 pm
Mine came off about 2 months ago in the Wattagans, Couldn't tell the difference other than the banging on the highway, it didn't seem to effect the handling much at all, shock relocation brackets are probably the best solution for these though as they alter the lower mount orientation by 90degrees to allow for forward back movement as well as side movement under articulation. I have seen these locally somewhere too but cant seem to find them. http://www.giz.com.tw/english/rv_produc ... .php?Id=54
GT.
Post Posted: Tue Jun 01, 2010 1:03 am
maybe here!
http://outdoorauto4x4.com/p/848533/suzu ... ckets.html
Post Posted: Tue Jun 01, 2010 7:32 am
Make's em easier for apprentice's to strip em in. :roll: :P
x2 on Mr Joe.
Post Posted: Tue Jun 01, 2010 7:57 am
i used the bolt and it is goin good.
but i think i might invest in some of those relocation brackets from .ODA1
Post Posted: Tue Jun 01, 2010 10:33 pm
With just one shock bolt missing in the Jimny, it makes for an awfully bumpy ride.
Users browsing this forum: BZOOK, Google [Bot], winchzook and 248 guests
