It is currently Tue Oct 27, 2026 7:21 am
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Sat Jun 05, 2010 5:33 am
My starter is going clicky click
Even when i short out the positive and the switching terminal on the starter it will still go 'click', additionally sometimes i can hear the starter whizz around but doesn't seem to engage?
Usually it will wrok properly after 2 or 3 clicks depending on how cold it is
Ideas to fix this?
Post Posted: Sat Jun 05, 2010 5:50 am
it sounds like it is the solenoid. I have never pulled a suzuki starter apart so i dont know if the soleniod is rebuildable. i would say pull it off and have a look see. my mates 80 series was doing the same thing and it was the contacts in the solenoid were worn. i welded some solder on the contact points and it was good as new.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Sat Jun 05, 2010 6:35 am
the starter motors on the suzukis are a completely different set up to the landcruiser starters. the contacts can not be replaced easily.
and dominator you can buy the contacts in the landcruiser starter motors as a replacement part. they arent that expensive. i would suggest changing them them as solder is as hard wearing as what was original.
try wiring up a starter relay. over time wiring gets resistance in it. causing a voltage drop. so the trigger wire wont be receiving battery voltage during crank.
you will need a relay, some lengths of wiring and some crimp terminal
if your not sure how to wire up the relay it is as followed
pin 30 - to battery positive (i pick this up from the main feed to the starter motor)
pin 85 - to the trigger wire on the starter motor
pin 86 - to earth
pin 87 - to the trigger on the starter motor (where the trigger wire was)
i would be doing this first as it is an in expensive thing to do and works a treat. if it wasnt starting at all then i would suggest a starter motor
Post Posted: Sat Jun 05, 2010 7:07 am
I did think of the relay trick but because it still happens when i shorted the terminals I dont reckon it's going to help at all
Post Posted: Sat Jun 05, 2010 7:10 am
what terminals did you short??
Post Posted: Sat Jun 05, 2010 8:08 am
The trigger and the positive on the solenoid...effectively giving the trigger as much amperage it wanted
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Sat Jun 05, 2010 8:11 am
well in that case i would either
A- replace the starter and wire up a relay
or
B- get yours rebuilt and wire up a relay
Post Posted: Sat Jun 05, 2010 8:55 am
yeah solder was only a temporary fix for the weekend. have since replaced the contacts. I wasn't sure if the zook contacts could be accessed or nor.
Post Posted: Sat Jun 05, 2010 10:41 am
it can be done.. but you have to pull the solenoid apart. no where near as easy as the nippon-denso units that the cruiser has.
i always replace it with a new solenoid
Users browsing this forum: No registered users and 136 guests
