It is currently Tue Oct 27, 2026 6:30 am
Post Posted: Thu Jun 17, 2010 2:25 am
ok well i was thinkin of getting
Sierra 6.5.1 reduction gears for $749.00
..but im not sure how much it would cost to get put in ...and if i need a heavy clutch ...as well ..i will find out but does anyone have a rough idea of cost ?
Post Posted: Thu Jun 17, 2010 2:41 am
Lowrangeoffroad has 6.5 gears, and gear install suppliment kit for US$590, after shipping and exchange rate etc, it will be cheaper than buying here.
Install you can do yourself, not too difficult. For the cost of labour to install it, you could probably buy the required tools etc and do it yourself.
If your clutch doesnt need to be changed, I wouldnt bother.
If it does need to be changed, I would also change the rear main seal, and input and output seals on the gearbox while you are at it.
I put an exedy heavy duty clutch in mine. Lots of people say HD clutches break clutch cables, but mine hasn't broken yet (25,000 km later).
Post Posted: Thu Jun 17, 2010 2:44 am
If you are reducing the gearing, you will be reduing the strain on the clutch, so an HD clutch would be IMO a waste of time and money...
I want my old sig back :(
Post Posted: Thu Jun 17, 2010 2:57 am
ok thxs i got the clutch part worked out ...my 2nd question is what should i reduce it to if i still want to use it on road is a 6.5:1 Reduction Gears
good for road use ...
Post Posted: Thu Jun 17, 2010 3:39 am
It all depends on tyre size...
Post Posted: Thu Jun 17, 2010 3:54 am
im running 31s atm
Post Posted: Thu Jun 17, 2010 4:00 am
6.5s and 31's would be a reasonable setup.
Vehicle: MY2019 Jimny
Post Posted: Thu Jun 17, 2010 4:22 am
That's what I run, it is fairly acceptable.
Post Posted: Thu Jun 17, 2010 4:31 am
Although, of course, it depends on what sort of driving you do, both on and off road...
Post Posted: Thu Jun 17, 2010 7:48 am
That's what I also run. Will do 110km/h on freeway no probs.
Post Posted: Thu Jun 17, 2010 8:21 am
A good site that does the math for you is here
http://www.lepayne.com/gears.html
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Users browsing this forum: No registered users and 224 guests
