It is currently Fri Jul 24, 2026 9:32 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Wed Jun 16, 2010 10:00 am
Jonno - forget about the states- anything for a car they didn't get there (like a LWB.... or a Maruti... or a fibreglass roof- is going to cost a fortune. Why? because the US supplier is probab;y buying it from a suzuki dealer in Japan, Europe or India, shipping it, putting their margin on, and then reselling and shipping to you.
Get a maruti VIN and go to a suzuki dealer here in Aus. you might be surprised- some parts are very reasonable.
PS the screen to seal is quite complex and generic foam won't work well.
Post Posted: Wed Jun 16, 2010 2:52 pm
Why all this talk of needing a Maruti VIN, FFS!
I've already posted the part numbers!
Vehicle: 91 Sierra
Post Posted: Thu Jun 17, 2010 10:51 am
jonno_racing wrote:
bit hard to make one.. i have NO idea what they look like to be honest! i am the only person i know with a maruti roof.
I think i have one, is this it ?
The rubber seals running along the 4 sides are a conbination of hard canvas and your typical door rubber. The back two corners have a moulded rubber foam insert bit. No rubber or seals actually fitted to the detachable roof bit.
Post Posted: Thu Jun 17, 2010 11:56 am
i have little to no idea why i said from the states.. that was ment to be from suzuki! literally the retail price was STUPID
yeah lauby thats the same!
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Thu Jun 17, 2010 12:01 pm
I use seals i bought from clark rubber.
Also with the whole VIN issue you should be able to use a VIN from an early WT seirra as that roof was also an optional factory extra for them.
Post Posted: Thu Jun 17, 2010 12:14 pm
u can buy them from clark?
Post Posted: Thu Jun 17, 2010 12:21 pm
Post Posted: Thu Jun 17, 2010 12:55 pm
yeah i would risk trying something else mate, like from clarkys or somewhere. the stock ones leak anyway so what ya got to lose! :wink:
Post Posted: Sat Jun 19, 2010 7:47 am
got some sticky back rubber from foam land today... appears to work well was easy to install etc... need a few new clips as the ones that came with my hard top are fucked and we will see...
Post Posted: Sat Jun 19, 2010 8:41 am
lauby wrote:
You don't have the important bit - the front corners. You're not getting those bits from clark rubber.
Post Posted: Mon Nov 12, 2012 12:41 pm
I rang Darwin Suzuki and they are $260 for the factory seals. Good value I reckon
Post Posted: Mon Nov 12, 2012 2:26 pm
I used seals from clarks
I followed the profile of the windscreen around the corner more, and the seals on the rails I made them a little longer, and cut them to suit the seal profile front and rear, and glued the side seals to front and back seals.
It doesnt leak.
The extra leaks I found were through the B-pillar seams.
Vehicle: 91 WT 1.6EFI
Post Posted: Mon Feb 11, 2013 8:13 am
Does anyone have a picture or diagram of the cross section of the maruti front section seals? just so I can take it to an extruder and find the closest match.
Vehicle: MG410 Gypsy
Post Posted: Tue Dec 15, 2020 8:00 am
Hey did anyone every find 'The back two corners have a moulded rubber foam insert bit.'
I have been looking for some time online with no luck.
Users browsing this forum: No registered users and 452 guests
