It is currently Tue Oct 27, 2026 6:31 am
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3  Next
Vehicle: Ducati Monster
Post Posted: Thu Jun 17, 2010 10:44 am
so what is the most popular kind and brand of diff locks being used here (welding doesn't count......)
Post Posted: Thu Jun 17, 2010 12:27 pm
Air lockers (ARB) are superior.
However auto lockers (Richmond Lockright) are cheap, and are effective. They are a bit suckful on road though, but it is tolerable.
Post Posted: Thu Jun 17, 2010 12:30 pm
dont be a tight ass, you will wish you spent the extra money later on....
Invest in dual air lockers
Post Posted: Thu Jun 17, 2010 12:32 pm
air lockers.... but currently my front one won't unlock.
Vehicle: MY2019 Jimny
Post Posted: Thu Jun 17, 2010 9:23 pm
Air lockers all the way.
They make a cool Pshhhhhh sound too!
Vehicle: '92 Sierra
Post Posted: Thu Jun 17, 2010 9:29 pm
Blocked exhaust vent on the solenoid? Or possibly gunk in the solenoid holding it open.
Post Posted: Thu Jun 17, 2010 9:33 pm
around $2800 for air lockers or around $550 for lockrights :wink:
if price is important get lockrights, if not get lockrights.
Post Posted: Thu Jun 17, 2010 9:38 pm
eh shep, image once i put all that work into the yellow thing.....and then went and put lockwrongs in it.......what a waste!........plus.....some of us care about how our vehicles drive. :wink:
Post Posted: Thu Jun 17, 2010 9:47 pm
x elleventy!!!!! :D
Post Posted: Thu Jun 17, 2010 10:27 pm
I'm sorry but the fact that you can no longer drive unlocked with an auto locker makes it crap to me! I'd rather have open diffs than a lockwrong. Air lockers give you both options :D
Clearance Hole Technology :P
Post Posted: Thu Jun 17, 2010 10:49 pm
Ill go welded over lockwrong
Post Posted: Thu Jun 17, 2010 11:51 pm
sounds definitive, thanks guys, i spose i will just start saving for some air lockers, then at least i can reinflate tyres on the spot too
Post Posted: Fri Jun 18, 2010 6:46 am
depends on how worn out your side gears are if you go the 1510 lockrights. Mine work nice and quietly as the side gears are not as tight as they would be if new. drives fine on the tar and lock up in the ruff stuff. the only down side i have found is the steering is alot heavier when locked and not as responsive on low traction tks.
Post Posted: Fri Jun 18, 2010 7:00 am
I have dual lockrites and daily drove my zuk for 5 years. It always handled amicably on the road. The back was a bit tail happy under acceleration in the wet but I suspect this has to do with 31" muddies other than anything else.
There is a mild clicking sound at very slow speeds (in a car park for instance) but apart from that there is nothing very noticeable.
As for the detractors who say that a front lockrite makes it hard to steer grow some muscles or stop been lazy and get out and unlock the hubs.
IMHO, air lockers are not worth the extra money. $2000 can do a lot of other mods for a Suzuki :P
Post Posted: Fri Jun 18, 2010 7:50 am
Save up, spend the money once and get Air Lockers you wont regret it.
And for those who say Air Lockers are to expensive its time to get a better job or a cheaper hobby.. :wink:
Post Posted: Fri Jun 18, 2010 8:06 am
Well said kenny :D
Post Posted: Fri Jun 18, 2010 8:11 am
I can't justify the expense of a airlocker in the rear of my sierra. I'm spooled and that suits my use and driving style fine. It's easy to justify an air locker for the front though. Being able to steer on slippery surfaces is cool.
Post Posted: Fri Jun 18, 2010 8:23 am
Hey Joe, If ARB make me some airlockers that fit 1 litre type diffs I'll pull out my Lockrights and smash them in a press! Until then they sure beat welded.
Post Posted: Fri Jun 18, 2010 8:31 am
agreed... I've had them all:
Welded= crap
Lockrite=crap
Phantom locker(form of LSD)=crap
ARB Airs front and rear ONLY way to go.= The Best
At least then you can try different lines to drive the obstacles and if required use rear or front or maybe both.
PS with front and rear Airs you can still enter the stocko class comps and clean up the field to take home the trophy and Frozen chook.
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Fri Jun 18, 2010 9:49 am
well.....i am building some new fabricated diffs for kenn's lj (wider with coils)........so he might have the current 1.3 front and 1.6 rear custom made diffs to suit an lj up for sale soon..... :wink: (would like to see them go to a good home)
Post Posted: Fri Jun 18, 2010 9:56 am
my vote goes to Airlockers.
i always wanted one in the front but after driving it in its current setup for a few years now i dont want a front locker on the grounds that it will make whats currently a challenging section of track much easier - and i prefer to keep it challenging, otherwise i have to go find harder tracks further from home and will have less people that would want to join me on a trip out.
Post Posted: Fri Jun 18, 2010 10:05 am
you don't want a front airlocker?......you could allways leave the switch off....
Post Posted: Fri Jun 18, 2010 10:48 am
what is a spooled diff?
Post Posted: Fri Jun 18, 2010 10:51 am
a spooled diff is like welded except designed from the ground up that way.
That is it is always permanently locked.
As for people who say buying lock-rites is the cheap way out. I have too many other expensive hobbies and can't justify spending $2k for no gain in off-ability or on-road manners (especially not that my zook will not be my daily drive... once it is finally back on the road that is :-( ).
Post Posted: Fri Jun 18, 2010 10:55 am
And there isn't currently an actual "spool"for a sierra diff, only a "mini spool" that fits inside the stock centre. You can get them from trail tough.
No doubt, if my car was a daily, it'd have an airlocker in the rear. If it's not a daily though, I think an airlocker is a waste of money for the rear.
Horses for courses.
Post Posted: Fri Jun 18, 2010 11:03 am
hmmm mini spool price was pretty good on the trail tough site, how much work or difficulty is involved in installing one?
Post Posted: Fri Jun 18, 2010 11:10 am
So why doesn't welding count? I bought a mini spool because I intended to use it in both a sierra rear diff and a vitara rear diff, which I have done. I've welded a bunch of sierra diffs and always had good results. Why is welding not an option if you are considering a mini spool? the effect is the same.
Post Posted: Fri Jun 18, 2010 11:15 am
Cause 90% of people cant or dont have access to welding gear to do it properly vs the cost of a mini spool
another vote for airlockers here, pucker factor on a rocky side angle with a rear end thats dragging cause its locked is shit
im not considering welding because it sounds like a cheap and nasty way of locking a diff even if it is done by a good welder, etc. im not really considering a mini spool, i am just asking about the different ways people go about locking their diffs to try to get more informed about the subject. I am leaning towards air lockers, even though they cost a packet they seem like the best and most user controllable option to me, like I said I am just trying to basically pick everyones brain and see what kind of results people get with the different methods used.
Post Posted: Fri Jun 18, 2010 11:21 am
Meh.... who cares where the rear is pointing? so long as the front's pointing up the hill it's all good - punch it! :D
I'm actually serious - I was taught long ago if the front's heading where you want, don't worry about the rear. There's something to be said for that. I do understand your point though, but I do drive a tray, so I have no bodywork to consider - I don't car what the back hits because it's swung around. (Actually, I don't consider my bodywork at all - another reason I run a spooled rear :wink:)
Users browsing this forum: No registered users and 222 guests
