It is currently Thu Oct 29, 2026 1:52 am
Post Posted: Sat Jun 26, 2010 7:24 am
I've had a bit of rust here for a while, but it seems its worse that I thought...
Any ideas what I should do with this?
I want my old sig back :(
Vehicle: 75 Cruiser
Post Posted: Sat Jun 26, 2010 7:28 am
cut it out before it goes to your windscreen hinge, which will then be harder to fix.
Post Posted: Sat Jun 26, 2010 7:33 am
X2. and remember, the rust you can see is normally only 10% of the rust that's there.
Have you folded the windscreen and checked the cowl is intact under the windscreen?
You have a lot of work ahead of you.... I'd try and find every bit of rust you can anywhere on the car and weigh up whether it's worth repairing it , or chasing a better tub.
Vehicle: 75 Cruiser
Post Posted: Sat Jun 26, 2010 7:41 am
as mr G said, see if you body is worth saving, if not, you can just do a dodgy fix up...
or
set aside a full weekend, take the windscreen surround off, take the dash out if necessary so you can access it better, cut it all out, weld some plate in it's place and spray nasty chemicals eveywhere, like rust converter. weld as much as you can so you only have to use minimal bog to just finish it off.
:cheers:
Post Posted: Sat Jun 26, 2010 7:44 am
Ok, I thought as much...
Next problem is, I can't weld...
Post Posted: Sat Jun 26, 2010 7:55 am
i've thought of this for when mine gets on a bit... i think the best solution is to buy a sierra body and restore that separately, and once its done do a body swap. means the cars not off the road long and the job done would be of a higher quality seeing as theres no great rush.
it would however also be about the most expensive option! lol
Vehicle: 75 Cruiser
Post Posted: Sat Jun 26, 2010 8:01 am
Ben_Sierra wrote:
I can't weld...
that never stopped me :lol:
worst case, take the windscreen surround off, hit it with a grinder with the wire brush, get as much rust out as you can , hit it with rust converter, then bog it up. That will give you a couple of years.
Post Posted: Sat Jun 26, 2010 8:13 am
steve wrote:
Ben_Sierra wrote:
I can't weld...
Its gonna end up being a hole the size of a fist or more.... its right through. How'm I gonna bog that up?
My old man suggested pop-riveting a plate behind it and then filling on top of that... But it sounds a bit dodgy to me...
Post Posted: Sat Jun 26, 2010 8:50 am
Ben_Sierra wrote:
steve wrote:
Ben_Sierra wrote:
I can't weld...
armsup done worse seen better.
if the rest of the cab is shot, but still safe there is no reason you cant do this to keep the police off your back while you save for a new cab.
Post Posted: Sat Jun 26, 2010 9:23 am
Ben_Sierra wrote:
steve wrote:
Ben_Sierra wrote:
I can't weld...
just tack it into place grid the tacks flat make sure ur new plate fits with with the smallest gap possible round the hole and the bog should fill in the small gap sorta like the pics but bigger by the looks of it
Post Posted: Sat Jun 26, 2010 10:34 am
You think you have problems..
Check my buildup, lwb..
Post Posted: Sat Jun 26, 2010 10:56 am
8O i just did fuck thats a lot of rust im not going to complain about mine agen :roll:
Post Posted: Sat Jun 26, 2010 10:59 am
She'll be fixed. Don't worry ;)
But Ben_sierra's section looks bad.
Mine is rusty on that corner, not as bad, but mine has mostly eaten floor and guards..
Post Posted: Sat Jun 26, 2010 11:08 am
thats good
yeah i had it like that on my windscreen surround but not as bad was just as bubbly tho
yeah mine had bit most of yours look like its just surface rust think i was lucky cos it looked like someone done a bit of fixing it already where the rear bar for the soft tops gos was replaced before i got it
Post Posted: Sat Jun 26, 2010 11:30 am
Most of mine is rusted through... I know this on account of the fact I can see the passenger footwell, and when I feel up behind the glovebox I can feel a good amount of rust...
Post Posted: Sat Jun 26, 2010 11:35 am
thats sounds bad should be able to do it the way i said before its how i did most of mine
thats the best i can do with pics my m8 went bit nuts with the welds but u should be able to see how i done it
Post Posted: Sat Jun 26, 2010 11:46 am
Start cutting, have to find out how bad it is, only way is to start cutting....
Don't call it buttercup tho.. 8O 8O 8O
Post Posted: Sat Jun 26, 2010 12:15 pm
had the same amount in my old sierra and exact same place. Paid a panel beater $600 to cut, weld, bog and paint it up. looked better than what i could thats for sure. i did under the car and the sills etc where it cant be seen but that is a major eye sore if u get it wrong there.
Post Posted: Sat Jun 26, 2010 12:58 pm
Sorry to sound un-caring, but seeing that makes me feel better about my LJ :lol:
Mate I can't weld very much, my front bar fell off my LJ in the last comp I was in :oops: ; but I would definitely give it a go (as opposed to leaving it), I am the lord of procrastinating and putting stuff off, but get into that ASAP!!!
Clearance Hole Technology :P
Vehicle: Jeep
Post Posted: Sat Jun 26, 2010 1:27 pm
Ben_Sierra wrote:
steve wrote:
Ben_Sierra wrote:
I can't weld...
Hmmm, that will learn you not to leave a rust spot to long, as it spreads very quickly, i talk from experience, learnt that the hard way... actually thats not a bad idea to patch the hole... only other option is to weld a plate in... or use some fibreglass, but you will need access to get underneath the hole... unfortunately there is no quick, easy and cheap fix for rust in that position... good luck... :roll: :wink: :D
Post Posted: Sat Jun 26, 2010 5:50 pm
If you can get your hands on a mig then all thats required are some tack welds. It's not really to had, just cut all the rust out, cut some sheet metal to size, do heaps of tack welds around the plate, grind down and put a little bog. Then make sure you prime top and bottom and it should be good for years.
This is some of the rust in my LJ :D
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Mon Jun 28, 2010 8:29 am
Well, just took the ol'girl to the local panel beater.
He said to leave her there and she'll be all done by Thursday. $250, not nearly as bad as I thought...
Post Posted: Mon Jun 28, 2010 8:37 am
That's pretty cheap, is he going to plate it up properly or just jam some bog in there... 8O
You should get him to fix any other little spots you find while he's got the paint in the gun or see if he will put the left over paint in a touch up tin for later on. :wink:
Post Posted: Mon Jun 28, 2010 8:39 am
thats good, for that price why mess around!
Vehicle: 93 Sierra
Post Posted: Mon Jun 28, 2010 8:40 am
:shock: Pics once done, thanks! I've got some rust under the windscreen rubber on my hard top that I'm not game to touch ... if he's any good I'll be paying him a visit!
Post Posted: Mon Jun 28, 2010 8:44 am
No painting, thats just for welding it up. He'll be leaving it in primer...
Post Posted: Mon Jun 28, 2010 9:58 am
does every one in this thread have a LJ?
Post Posted: Wed Jun 30, 2010 9:14 am
Ok, well I just got her back from the panel beaters, and he did exactly what I asked, i.e. weld it up and leave it at that. He also found the closest matching paint he had lying around and stuck it over the bare metal to protect it until I get round to bogging and painting it. And he kept his word on the price, $250, for the three spots of rust that I found.
Here are the results:
Post Posted: Wed Jun 30, 2010 9:18 am
wow - not only was he cheap but he finished on time too (or early!)..
Post Posted: Wed Jun 30, 2010 9:20 am
Yep, I can't complain. The best thing was he just fit me in there and then, no waiting!
Anyone in Perth need panel beating, PM me and I'll get you his details!
Users browsing this forum: No registered users and 736 guests
