It is currently Wed Oct 28, 2026 7:37 am
Vehicle: 07 vvt jimny
Post Posted: Wed Jul 07, 2010 1:09 am
for a while now i have had wandering issues with my sierra's steering and now its off the road, im going to fix a few issues
the joint from the pitman arm to the drag-rod is fu*ked so sloppy and loose. Now I have undone the top nut and removed the split pin and the prick wont come out. says in my manual i need a two-jaw puller to remove the joint.
now my other problem is do i have to remove the whole drag rod and what eva and have new joint put in " do they need to be pressed or anything" or is it simple push out and put in new one. also where do i get new joint from.
cheers
Josh
sorry CHOP :P
Jimny's Are taking Over
Vehicle: MY2019 Jimny
Post Posted: Wed Jul 07, 2010 1:21 am
Don't the new ball ends just screw in?
Post Posted: Wed Jul 07, 2010 1:29 am
sorry i think your thinking of the tie-rod end that screws in, the drag rod connects off of that and goes up to the pitman arm which is connected to the steering gear/ box around where the steering damper is.
i can see i need to press the bolt comming up through the pitman arm but then what do i do to replace the stuffed bushing/joint ???????????????????????
sorry CHOP :P
Post Posted: Wed Jul 07, 2010 1:35 am
Um can you take a pic?
So the pitman arm is flogged out?
Post Posted: Wed Jul 07, 2010 1:47 am
unfortunatly the mrs has gone to work and always has the camera in her bag :S:S:S
yea the pitman arm joint to the drag-rod if flogged alright.
i need to get these jaw-puller things cause i cant pull the drag-rod off the knuckles to get to the joint/bolts to replace them
sorry CHOP :P
Post Posted: Wed Jul 07, 2010 1:51 am
Sounds like you need a new pitman arm then, I think it is just a tapered hole, don't think there is a bush in there.
Post Posted: Wed Jul 07, 2010 4:16 am
You be around tomorrow Josh? I'll drop by and show you how to remove it.
Post Posted: Wed Jul 07, 2010 4:25 am
yep i'll be around till the 26th of this month till i start my auto mechanics tafe course lol. oh oh oh on that note i wont be round 2moro untill about 11am have to look for some work placement for my tafe need a mechanis business too take me on for 1-2 days a week have to build up 200hrs during my course so come on any places out there lol.
sorry CHOP :P
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Wed Jul 07, 2010 4:29 am
take out the split pin and loosen the nut but leave it on a few turns hit the side of the pit arm right where the bolt goes through might take a few goes but it should drop out because it is tapered. just did it to my car the other day.
Post Posted: Wed Jul 07, 2010 5:13 am
ive wd-40'd it all, and i will keep on the slight taps to see if it comes off will let ya know how it pans out.
sorry CHOP :P
Post Posted: Wed Jul 07, 2010 6:20 am
I'm pretty sure the ball joint is integral into the drag link - they certainly don't unscrew.
Post Posted: Wed Jul 07, 2010 6:54 am
maybe you can "upgrade" - a few places make crmo replacement steering linkages, then its just a case of unbolting the lot and throwing on the new one.
Don't forget if you touch the tie-rod you're going to throw out the wheel alignment.
Post Posted: Wed Jul 07, 2010 7:07 am
all good im not touching the tie-rod im touching the drag-rod its the first bar after the steering box.
wants 33's has upgraded his by welding a steel sleeve around it i have seen in his pics. im keen to do that whiles its off " well when i get it off still cant get it off its held on there good it just wont slide off over the bolts, and yes i have undone the split pin and nut lol "
sorry CHOP :P
Post Posted: Wed Jul 07, 2010 8:14 am
i remember when we took mine off years ago it needed some heat (oxy) and a hammer... don't forget its been in there for around 20 years =) its happy to stay put... lol
Post Posted: Wed Jul 07, 2010 9:02 am
you will either need to hit it hard and itl come out. or use a puller! may as well buy one now ul use it heaps as a mechanic :wink:
Users browsing this forum: Google [Bot] and 295 guests
