| Author |
Message |
BlueSuzy
 Posted: Tue Jul 13, 2010 1:15 pm |
I am after the measurement of a compressed vitara Rear spring/s
State your type of vit:
Stock or aftermarket lifted spring/size lift:
Compressed Length:
Please! I need this as an estimate for my lwb build.
Bucket
Joined: Mon Nov 30, 2009 10:30 pm Posts: 2191 Location: Vic
Vehicle: SJ50 hardtop!
 Posted: Tue Jul 13, 2010 2:15 pm |
compressed lengths as in the car being on a flat piece of ground, or flexed up?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jul 13, 2010 10:13 pm |
Any of you Vit guys used 120Y front coils????
Another forum I'm on, they are commonly used to give a 2 lift.
Fatzook
 Posted: Tue Jul 13, 2010 10:18 pm |
want33s wrote: Any of you Vit guys used 120Y front coils???? Another forum I'm on, they are commonly used to give a 2 lift.
And they're probably the only part of a 120Y that hasn't rusted back to the earth from once it came
BlueSuzy
 Posted: Tue Jul 13, 2010 10:53 pm |
Sorry
Flat ground. No flexing.
BlueSuzy
 Posted: Wed Jul 14, 2010 8:37 am |
jeez i thought id get an answer straight away..
Fatzook
 Posted: Wed Jul 14, 2010 8:39 am |
BlueSuzy wrote: jeez i thought id get an answer straight away..
So you are looking for the static height? Thats with the weight of the vehcile on flat ground?
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Wed Jul 14, 2010 8:42 am |
i have a vit rear spring here, sitting unloaded (out of car). or did u want it in the car sitting flat?
mitch
matty_wall
Joined: Sun Feb 15, 2009 10:30 pm Posts: 989 Location: Blue Mountains
Vehicle: SJ51T
 Posted: Wed Jul 14, 2010 9:15 am |
275mm. Top spring perch to the end of the base of the spring.
40mm raised king springs.
SWB soft top vitara.
BlueSuzy
 Posted: Wed Jul 14, 2010 9:21 am |
yes fat zook. Static heights.
A car on the road. Flat ground. No flexxing.
I have 1.6 swb vit rears, 2.0v6 lwb vit rears, and jimny rears here.
I am making spring top pearches with no body, ie, no weight. so i need an estimate height on where to put them.
Fatzook
 Posted: Wed Jul 14, 2010 9:25 am |
BlueSuzy wrote: yes fat zook. Static heights.
This is for a sierra?
Thats going to be very hard to do, as the vierra and vitara weight are different.  Can you just tack the top coil buckets on and check with the body on and move up or down at a later date?
BlueSuzy
 Posted: Wed Jul 14, 2010 9:51 am |
i can do that. But i want it close to begin with.
Thanks mattywall!
An estimate is all i need!
So the jimnys should be similar. They have less coils, but are higher sitting next to each other.laying on the ground. Lighter car also.
