It is currently Fri Oct 30, 2026 7:53 am
Post Posted: Tue Jul 13, 2010 1:15 pm
I am after the measurement of a compressed vitara Rear spring/s
State your type of vit:
Stock or aftermarket lifted spring/size lift:
Compressed Length:
Please! I need this as an estimate for my lwb build.
Vehicle: SJ50 hardtop!
Post Posted: Tue Jul 13, 2010 2:15 pm
compressed lengths as in the car being on a flat piece of ground, or flexed up?
NT SJ50
Post Posted: Tue Jul 13, 2010 10:13 pm
Any of you Vit guys used 120Y front coils????
Another forum I'm on, they are commonly used to give a 2 lift.
Post Posted: Tue Jul 13, 2010 10:18 pm
And they're probably the only part of a 120Y that hasn't rusted back to the earth from once it came :lol:
Post Posted: Tue Jul 13, 2010 10:53 pm
Sorry
Flat ground. No flexing.
Post Posted: Wed Jul 14, 2010 8:37 am
jeez i thought id get an answer straight away..
Post Posted: Wed Jul 14, 2010 8:39 am
So you are looking for the static height? Thats with the weight of the vehcile on flat ground?
Post Posted: Wed Jul 14, 2010 8:42 am
i have a vit rear spring here, sitting unloaded (out of car). or did u want it in the car sitting flat?
mitch
Vehicle: SJ51T
Post Posted: Wed Jul 14, 2010 9:15 am
275mm. Top spring perch to the end of the base of the spring.
40mm raised king springs.
SWB soft top vitara.
Post Posted: Wed Jul 14, 2010 9:21 am
yes fat zook. Static heights.
A car on the road. Flat ground. No flexxing.
I have 1.6 swb vit rears, 2.0v6 lwb vit rears, and jimny rears here.
I am making spring top pearches with no body, ie, no weight. so i need an estimate height on where to put them.
Post Posted: Wed Jul 14, 2010 9:25 am
This is for a sierra?
Thats going to be very hard to do, as the vierra and vitara weight are different. :? Can you just tack the top coil buckets on and check with the body on and move up or down at a later date?
Post Posted: Wed Jul 14, 2010 9:51 am
i can do that. But i want it close to begin with. :lol:
Thanks mattywall!
An estimate is all i need!
So the jimnys should be similar. They have less coils, but are higher sitting next to each other.laying on the ground. Lighter car also.
Users browsing this forum: No registered users and 365 guests
