It is currently Fri Oct 30, 2026 7:19 pm
Post Posted: Tue Jul 20, 2010 1:11 pm
hi ppl i'm looking at a 01 2.5 v6 are they any good and do i need to look out for anything. thanks for ur time.
Post Posted: Tue Jul 20, 2010 1:18 pm
Hi.
Welcome to Auszookers!
I have no idea about the 2.5L.
But what do you intend to use it for? Offroad? touring? Highway driving?
Pete
Post Posted: Tue Jul 20, 2010 1:23 pm
Welcome to AZ!
I have a 01 2.5 V6 in manual. Got it at 65k about 2 years ago and now its got 120k.
Main thing to look out for is the timing chain rattle - do a search and theres plenty of info about this. Basically it makes a rattling noise at cold start up. If it has been looked after it'll still make the same noise but only for a second or two. Any longer than that you'll need to be careful.
Other than that, beside for normal wear and tear I haven't had any problems. 8)
Post Posted: Tue Jul 20, 2010 1:24 pm
both i guess more highway but
Post Posted: Tue Jul 20, 2010 1:28 pm
shabz wrote:
Welcome to AZ!
sweet anygood for the bush and if so what are some good basic mods i should do. thanks
Post Posted: Tue Jul 20, 2010 1:47 pm
welcome to auszookers!
decent AT or MT tyres that are slightly larger & a suspension lift will take you most places within reason, it really depends on how far you want to venture off road, there are a few nice GV builds in the members section.
Post Posted: Tue Jul 20, 2010 1:49 pm
EDIT: there was a problem with the early ones poping out of 4wd hi-range have a search on here for a thread started gravity_powered, not sure of the year that suzuki fixed it but there is a fair bit of info floating around on the subject
Vehicle: Jeep
Post Posted: Wed Jul 21, 2010 3:56 am
X 2
I just bought a 2001 2.5 V6 a few months ago, i have taken it offroad stock on gravel and rocky tracks with deep ruts, and it did surprisingly well, but i am just about to get a Suspension lift kit put on from Ironman, and trying to get some decent AT's and Rims, the GV has a bit of a narrow rear wheel arch, 30inches or 761mm, so you have to be a bit carefull when selecting AT's that the tyre outside diameter fits in, i have found that generally, the 225/70R16 will fit the best... have a read of my rig thread, link is below...
The series two GV is the one to look for, as most of the previous series problems, were fixed in the series two, you can tell the series two GV, by the chrome strip just above the front grill, and in front of the bonnet...
They are a great Zook, goes very well onroad, its a very comfy road tourer, and with a few mods, will become even better offroad, it wont be as capable as a Sierra or a Vitara, unless you do some extreme mods, but they will handle most of what you throw at it, and the GV still has that well known Zook sand floating ability, the GV is still lighter than most big 4WD's, about 1400kgs... have fun with your GV, i know i will when the mods are done ! :wink: :lol:
Post Posted: Wed Jul 21, 2010 4:48 am
blackout.81 wrote:
shabz wrote:
Welcome to AZ!
Tyres would be a first. tougher 4wd tracks and a 2" lift will be better. I use mine as a daily driver and offroad every few weekends for day/weekend trips etc. Makes a great tourer and very capable off road with just these mods. Also agree with MacBear - i believe the second series GV's started in 01, August i think.
Post Posted: Wed Jul 21, 2010 12:00 pm
thankyou for the help but 1 more thing how are they on fuel
Post Posted: Wed Jul 21, 2010 12:10 pm
Fuel consumption isn't fantastic for the size of the car. 10.5l/100km is about the best I've got driving like Betty White, 12l/100km is average.
Post Posted: Wed Jul 21, 2010 12:50 pm
thank you for your help im picking it up friday
Post Posted: Wed Jul 21, 2010 2:32 pm
blackout.81 wrote:
shabz wrote:
Welcome to AZ!
Really good in the bush actually! I've never been close to getting stuck. Having said that though i do mainly touring. Around the vic high country i have attempted several 'double black diamond' tracks (rated as extremely difficult) in dry conditions, and never had any worries!
i have the ironman 2inch lift and 225/75 BFG AT tyres - thats it as far as mods go 8) Does the job well and still drives nice on road.
Vehicle: Jeep
Post Posted: Wed Jul 21, 2010 3:30 pm
I disagree, i dont drive like an old lady, i push the pedal a bit, lol, but i get less than that... i use Flash Lube, a Valve saver/Lead replacement/Upper Cylinder Lubricant, fuel system and injector cleaner additive in the tank every third tank refill, and i get great fuel economy, i can go 50kms before it moves off Full, i have just done 230kms from full, and the fuel gauge is still between half and three quarters, all i can say if you are using that much fuel, that your injectors must be dirty, plugs need changing, or engine has some fault... :roll: :wink: :lol:
Vehicle: 2004 SQ625 GV
Post Posted: Thu Jul 22, 2010 4:28 am
you could probaby pay for another tank of fuel for all the money spent on addatives :lol:
Post Posted: Thu Jul 22, 2010 4:31 am
If you put bigger tyres and a lift I would say it performs as well if not better than the new IFS hiluxs off road
Post Posted: Thu Jul 22, 2010 4:35 am
Why do you need Valve saver/Lead replacement/Upper Cylinder Lubricant? I don't recall any cases of the valves wearing out, unless you're on LPG.
I think you also run 95/98 fuel don't you? The higher spec fuel is cleaner and has those additives in it anyways.
2002 SWB GV
Lifted and Locked
Vehicle: Jeep
Post Posted: Thu Jul 22, 2010 6:29 am
Nope... 1 bottle lasts me for 3 months, and its only $18 per bottle... :wink: :lol:
Vehicle: Jeep
Post Posted: Thu Jul 22, 2010 6:38 am
Ha ha, well it does alot more than just being " Valve saver/Lead replacement/Upper Cylinder Lubricant " !
BENEFITS -
Protects Valves and Valve seats from wear
Increases fuel economy
Cleans Injectors and Fuel System
Reduces emissions
Increases Engine Life
Reduces Engine Temperature
Yes i do also only use Premium Unleaded 95, it may have those additives, but i dont think they would be in any significant quantities... i like to look after my Zook, and if a $1.50 bit of a $18 dollar bottle of extra additive protection in my Zook every once in a while, helps extend its engine life, and make it run better, then, sure i will spend that money to do it ! :wink: :lol:
Post Posted: Thu Jul 22, 2010 9:22 am
BENEFITS -
Reduces emissions
I totaly agree with you Mr Bear, if you spend a dollar on prevention it saves you ten on repairs...
And my answer to the original question in this post is YES ,my 2000 2.5 v6 GV is one of the best cars i have ever owned ,it will be sad to see it go , but the new ones are even better (for what i want it for) thow a little thirsty..
Post Posted: Fri Jul 23, 2010 2:14 am
thankyou ppl i got the grand vitara limited sports 01 2.5 v6 so far so good but shit it drinks petrol like its free and suzi dealer said its spot on. 16ltper 100km maybe some1 with a brain can help me out.
Post Posted: Fri Jul 23, 2010 3:47 am
O2 sensor ?
Post Posted: Fri Jul 23, 2010 12:14 pm
X2 mine did about 11L /100km in traffic with a trady trailer on the back,day in day out..
Post Posted: Fri Jul 23, 2010 1:50 pm
i will get 10-11ltrs/100 kays depending city or highway driving.....maybe now you you have it just give it a good service to start with and see how you go.
Vehicle: Jeep
Post Posted: Fri Jul 23, 2010 2:45 pm
Wow, 16L per 100kms is ALOT ! 8O 8O 8O
I dont care what that Suzi Dealer said, something is wrong there... :?
Post Posted: Fri Jul 23, 2010 3:02 pm
I think i get that with a 1,6...! Shoots it out the exhaust!
Vehicle: Jeep
Post Posted: Fri Jul 23, 2010 6:19 pm
Jeez 8O 8O 8O
Post Posted: Sun Jul 25, 2010 9:15 am
they told me O2 sensor are okay i done the service my self i don't know what else to do
Vehicle: 02 GV
Post Posted: Sun Jul 25, 2010 9:53 am
mine does about 17l/100km's around town, 12l/100km's on the highway, i've put it down to being an auto.
i recently towed a camper trailer (1122 atm) and still averages 17l on the highway sitting on 110km/hr so i'm happy bout that. better than a cruiser.
Post Posted: Sun Jul 25, 2010 3:42 pm
so its the auto you say. shit thats no good. why did i get something the wife can drive. shit
Users browsing this forum: No registered users and 378 guests
