It is currently Wed Oct 28, 2026 4:18 pm
Post Posted: Sat Jul 24, 2010 10:02 am
Hey! the battery in my new heapajunk (95 lwb v6) is pretty knackered, and i'm chasing up a new one, since there is only enough room for 1 battery in the engine bay, bigger is obviously better? Has anyone had any luck fitting something like a N70ZZ in there? or would that be going too big? :wink:
Go Hard, Trailer Home
Post Posted: Sat Jul 24, 2010 10:21 am
which side is it on? I have a NS40Z on the drivers side and a N70 on the passenger side, the v6 doesnt have anything in those spots does it?
Post Posted: Sat Jul 24, 2010 10:27 am
batterys on the passengers side... has all the abs crap on the drivers side, height and width of the n70zz is the same as a n70, only the length that differs... its about 300mm long. Looks like it shoud fit, will be tight tho :wink:
Post Posted: Sat Jul 24, 2010 10:29 am
i have a black battery.. not sure if it's the zz or just the n70 :oops:
Post Posted: Sat Jul 24, 2010 10:38 am
if its on that side you should be able to go to 300mm easy enough, I cut the tray flat and bolted a generic tray onto it for mine, jsut triple check the height, the 120 ah/hr agm I had in before put a dent in the bonnet :)
Post Posted: Sat Jul 24, 2010 11:07 am
n70zz is same height as existing battery, and bonnet already had dents from previous battery...so should fit :lol:
Post Posted: Sat Jul 24, 2010 9:20 pm
Big battery......
Vehicle: Jeep
Post Posted: Sun Jul 25, 2010 4:28 am
Why is it a " heapajunk (95 lwb v6) " ??? :roll:
Or are you just being funny... :wink: :lol:
Post Posted: Sun Jul 25, 2010 4:34 am
cause it's a cross bread hybrid biatch...
Post Posted: Sun Jul 25, 2010 11:12 am
i do have other names for it but it would be disrespectfull to our indigenous cousins if i posted it up here :wink:
hows this for a squeeze Armsup
710cca of pure power, should sort out all my power problems 8)
i originally had the terminals to the front, but the bonnet didnt like them too much, so had to swap it over and place the terminals to the rear...bonnet just clears now!
Post Posted: Sun Jul 25, 2010 11:15 am
^^^ nice earth lead & clamp, i reckon my speakers have thicker wire. :oops:
terminals at the back is the standard position.
Post Posted: Sun Jul 25, 2010 11:35 am
bs! its all stock, thats all my other dungas got :roll:
Vehicle: Jeep
Post Posted: Sun Jul 25, 2010 4:28 pm
Jeez 8O with over 700CCA, i would be putting a bit of thick rubber or some insulation between your bonnet and the positive terminal of that battery matey, cause if that dead shorts to your bonnet, like bouncing when 4WDing, you gonna be in BIG trouble ! :roll: :? :wink: :lol:
Users browsing this forum: No registered users and 361 guests
