It is currently Thu Oct 29, 2026 1:03 am
Vehicle: '94 suzuki maruti
Post Posted: Sat Jul 31, 2010 1:09 am
ive done quite a bit of searching, looking for some information... my rear output seal on my transfer case needs replacing, but nowhere local sells the 28mm socket needed to remove the nut on the flange...
im going to get a mechanic to do it, only because i dont have the right size socket. is it as simple as: remove the nut, remove the flange and the seal is right there? ive read both yes and no to that... im just trying to work out rough cost of it...
Post Posted: Sat Jul 31, 2010 1:17 am
Yep, depending on the condition of your case, the flange and nut may be quite hard to get off. You'll most probably need a breaker bar to crack the nut and a bearing puller to get the flange off if your doing it yourself.
Post Posted: Sat Jul 31, 2010 1:26 am
Yeh mate it uss that simple...
the nut may be tight and the flange may be tight. But that is all.fairly simple job.
Post Posted: Sat Jul 31, 2010 1:52 am
ahh sweet. mite jst call mechanic monday... thanks for the help!
Post Posted: Sat Jul 31, 2010 2:07 am
you could do it in 15mins, just get a rattle gun and it will come off no worries...
Vehicle: Clown Car..
Post Posted: Sat Jul 31, 2010 2:39 am
yes.. but as mentioned by the OP....
[quote=''wincup'']nowhere local sells the 28mm socket needed to remove the nut on the flange... [/quote]
any decent mechanic will have the required socket.. flick em a 6 pack and see if they will loan it to you... or if you wanted to order it off the net...
http://www.getprice.com.au/ULTIMATE-3-4 ... 739559.htm
37 buckaroos...
Post Posted: Sat Jul 31, 2010 10:15 pm
37 buckaroos...[/quote]
OP?
Post Posted: Sun Aug 01, 2010 4:34 am
the nut is 27mm not 28.
Post Posted: Sun Aug 01, 2010 7:52 am
service manual i have off the internet says 28mm... does anyone know if it was the same across all sierra's?
Post Posted: Sun Aug 01, 2010 7:56 am
OP?
OP = Original Poster :D
Post Posted: Sun Aug 01, 2010 7:58 am
no actually my service manual doesnt say what size to use... i read it here, its step four:
http://zukioffroad.com/Tech_Library/tra ... nstall.htm
Users browsing this forum: Google [Bot] and 480 guests
