It is currently Thu Jul 30, 2026 1:43 am
Post Posted: Thu Aug 05, 2010 11:25 am
hey all i know i have another thread from a few weeks ago about my locrite/wrong and cromos.
im out in the shed fitting it now and am wondering if i have done it wrong?with the new axles just sitting in there and me spinning it by hand it appears they cant unlock from each other.
i have the 1530 with couplers.i installed the thrust washer from the standard side gears and then also between each half i installed the spacer ring(tube) supplied with the locker.I am wondring if it is packed out too far and cant disengage or if i need wheels etc on it and then try with more leverage of course as its a fair ask by hand?
thanks anyone
Vehicle: Sierra Utey!
Post Posted: Thu Aug 05, 2010 11:39 am
Drop a wheel on the ground and try again, and make sure you put a wheel on the hub you are tryimg to spin for more leverage. Then give it a good yank!
My ute..
Post Posted: Thu Aug 05, 2010 11:45 am
i have it only as the centre on the ground so far,all assembled back up so from the way you have said that it will neer work no matter how hard i yank which is sort of what i was thinking,then a mate confirmed :oops: :oops:
too late for this i thnk,try another day.
Post Posted: Thu Aug 05, 2010 11:46 am
agreed. it should be fairly solid to unlock if that makes sense, the act of the bitumen gripping and turning both sides at different speeds is what unlocks it, more of an auto unlocker if anything.
Post Posted: Thu Aug 05, 2010 11:54 am
Exactly. I'd be very surprised if you could get it to unlock as only a center on the ground. As long as you followed the instructions, you'll be right. Just whack it all back together, there's really not much to them so I'm sure you'll be fine.
My ute..
Post Posted: Thu Aug 05, 2010 12:05 pm
yeah tru,cheers.locker took about 5 minutes to put together if i have it right :oops: ,everything else is the slow bit,new wheel bearings etc,packin everything.
Ah well ill try put it in as is over the weekend and see how it goes.still trying to make sense of the squared coupler setup over the tapered style with original side gears.i guess im not a superhero and cant unlock it myself :lol: i didnt know what to expect to be honest
THANKS anyway 8)
Post Posted: Thu Aug 05, 2010 12:13 pm
I'll tell you what to expect with those couplers - Brrooommm, CLICK CLICK, CHIRP, BANG, CHIRP, CLICK CLICK......brrrroooommmmm....BAAAANG! :P
My ute..
Post Posted: Thu Aug 05, 2010 12:15 pm
mine will spin backwards by hand with one person on each wheel fairly easily. i took standard washers out and just used the bigger ones supplied with locker. i didnt get new couplers tho, just used old gears
Post Posted: Thu Aug 05, 2010 12:35 pm
thanks tasook,mines the coupler one tho so has different washers in the kit i think
has anyone else done one with a 1530 into a 2 pin n only have the 2 short pins left over??if so im happy
Post Posted: Thu Aug 05, 2010 12:38 pm
thanks crunched you have been a great help :? :lol: :lol: :lol:
thats about the only thing i did know about a locrite,but i thought id give one a try for now.see what happens in the future if i go air or lux diffs
Post Posted: Thu Aug 05, 2010 12:44 pm
Anytime! :P
I've got lockright's front and rear and they do the job. I don't mind the clunking they make (although mine run the standard side gears), it's the slop in them that I hate. You can have your backlash set perfectly and still have quite a bit of play, it's just the design of the beast. Where the pins locate through the two dog clutches is where the play is - translates to a fair thud in the driveline. You get used to it after a while, but it can still be a pain in the rectum.
My ute..
Post Posted: Thu Aug 05, 2010 7:11 pm
Crunched wrote:
Anytime! :P
:roll: I have 26 spline side's here.. :roll:
:P So do you now!!! :lol: :lol: That 3.9 should have a set.. :lol:
Post Posted: Thu Aug 05, 2010 8:03 pm
i hate noises under my car,so its gonna take some gettin used to eh.Atleast if i know what it is and why i should be right
a pain in the rectum you say :? 8O :lol: sicko
Post Posted: Thu Aug 05, 2010 8:26 pm
Reminds me of that little Johnny joke -
They're sitting in class one day talking about what they got up to on the weekend, all the little girls had been playing with their barbie dolls, all the boys had been playing with their toys cars etc.
The teacher asks Johnny what he got up to on the weekend and he says "I stuck a cracker up a frogs ass and blew it up!" and the teacher says "rectum Johnny, rectum." then Johnny says "Fucken oath it rectum!".
My ute..
Post Posted: Fri Aug 06, 2010 8:03 am
ritio off work for another day finally,so out to the shed.
my locker goes ...thrust washer,than coupler,than locrite driver with springs and pins,then spacer tube inside it,pin through carrier,driver again with springs and pins and spacer tube,then coupler,thrust washer.closed all back up so fingers crossed its right as im about to go seal it in the housing and pack my cromos
Post Posted: Fri Aug 06, 2010 8:23 am
To check it you can put 1 wheel on the ground with the other jacked up, turn the pinion flange by hand (it won't spin, just loads up) the other wheel should spin easily by hand with a light clicking noise in the same direction as the one on the ground is trying to spin( but not the other way). If it does this on both sides in both directions it's all good.
Post Posted: Fri Aug 06, 2010 8:44 am
ok when i get it assembled that far ill look at that.thanks heaps man
Post Posted: Fri Aug 06, 2010 9:13 am
seems im wasting my time and money.cant slide short side in so its looking like the diff is bent,slide in other side easy enough :evil: :x :x
zuk for sale eh
Post Posted: Fri Aug 06, 2010 9:33 am
many people had luck getting a shop to straighten them??or have one for sale thats good?
or sell up my brand new locrite n cromos and go lux diffs??? :x :x :x
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Aug 06, 2010 10:41 am
I just bought a new housing when I bent mine. It was not expensive.
Post Posted: Fri Aug 06, 2010 10:47 am
60T press at work if your keen :lol:
Post Posted: Fri Aug 06, 2010 10:52 am
zuk for sale eh
It wont fit as in it hits something solid or it gets to a point and then stiffens up or binds as if it is going in on the piss. That sounded wrong :oops: but you get the idea.
Is the centre bolted in completely ? The CV isnt hitting on the ball ? Did you grease the pins up when you put them in, to hold them in place during assembly ? When I sold one to Brodie and he was having problems fitting it, it turned out one of the pins on the inside had fallen out and was putting one of the drivers on the piss, so when you tried to put the axle in it would get to a point then bind.
Post Posted: Fri Aug 06, 2010 3:57 pm
na just turns out im a crackhead :oops: :lol: measured it up side to side with the long axle hanging out,measured up to be reasonably straight if not spot on so i kept trying,all of a sudden worked,dunno what i done different but yeah it all is in so i got everything back together enough that ill add oil in the morning,fit tyres and see if it works.
Post Posted: Mon Aug 09, 2010 11:33 am
took it for a quick drive on the weekend up a grassy hill.still dont know if its working properly yet allthough it did seem to climb it easy and slow.steering didnt feel much different with power steer allthough can feel slight resistance through the steering i guess.doing 3 cyls method it works right,binds up when spinning tailshaft.wheel off ground can spin when spinning it at the wheel but makes the clicky click sounds etc both sides both ways.havent really heard it make a bang so far driving and ave no where close to here to really make it spin n need front locker with back allready being locked
im sure steering will be heavier in different situations but so far in the grass if thats as bad as it gets the power steer is awesome 8)
Post Posted: Mon Aug 09, 2010 11:53 am
And just remember, we exaggerate quite a bit here on AZ. :P
My ute..
Post Posted: Mon Aug 09, 2010 11:55 am
haha ill remember that,na man it seems good so thanks for ya help along the way.sucks how long the job took for a 2 minute locker install lol.hopefully now with welded rear and locrite front i can go drive some cool shyt :lol:
Post Posted: Mon Aug 09, 2010 11:57 am
It'll be a new car. The real test for the steering will be when you have the front hubs locked in on sand/soft stuff whilst trying to make a really tight turn. The fronts will want to just pull you forward, instead of around. But you'll still love it and it will go anywhere. Mine's a mountain goat with the front locked in and the treps howlin'.
My ute..
Post Posted: Mon Aug 09, 2010 11:59 am
well ill be fitting my 31 treps in the next couple of weeks also 8)
my lux has twin arbs on 33s,has for a couple of months now,its not real flash to steer locked in
Post Posted: Mon Aug 09, 2010 12:01 pm
Then you will be loving it!
What's this hilux garbage you speakin? What you talkin bout appsie?
:lol:
My ute..
Post Posted: Mon Aug 09, 2010 12:26 pm
hey its a good thing, i like my hilux.the zook is just the toy and hobbie car to play on
ill always love zuks.
Users browsing this forum: No registered users and 789 guests
