It is currently Thu Jul 23, 2026 2:34 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Mon Aug 09, 2010 8:32 am
Time to have a bit of a clean up
vitara 1.6 clutch cable. good condition. just a tear in the rubber on the bottom. $ 15
Drover Headlights n frames X4 $10 each
Vitara steering column with barrel and key $20
Sierra petrol tank $40
Custom rear bar and tow bar suit 2 inch body lift with LED tail lights $100
Vitar dash loom and switches $10
sierra steering box x2 $65 each
WT rear centre. perfect condition $250
NT front centre $100
rear seat out of WT $80
1.3 airbox $20
2 1/2 inch stainless snorkel. made for 1.6 conversion $200
1 ltr transfer case. no switch. $80
1 ltr front tail shaft $40
1.3 spindles and hubs $50 for a pair.
Got more stuff lying around. let me know what you need. have a few sierras here im wrecking. if you need anythin let me know. Stuff located in ballarat Vic, will post smaller items
Post Posted: Mon Aug 09, 2010 8:33 am
Snake racing stuff and custom bar is to suit sierra
Post Posted: Mon Aug 09, 2010 8:35 am
ill take the starter if its good
cheers andrew
Post Posted: Mon Aug 09, 2010 8:37 am
No worries. Starter was fine
i may be interested in the rear bar...
would you be able to post some pics?
thanks...
Ross
Post Posted: Mon Aug 09, 2010 8:39 am
Yeah I'll put a pic up shortly
Post Posted: Mon Aug 09, 2010 9:31 am
some pics
roll bar to suit high top $180 SOLD
wheel bearing kit. pretty sure it suits NT $40
vitara dash $40
Post Posted: Mon Aug 09, 2010 10:20 am
pics of high steer arm???
819FKA has Been UNLEASHED
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Aug 09, 2010 10:21 am
Got any wide track diffs (end to end) in those sierras you are wrecking?
Post Posted: Mon Aug 09, 2010 10:22 am
Snake racing tail shaft spacer $30
WT or NT spacing? thickness?
Bitumen...Another waste of public funds!
Post Posted: Mon Aug 09, 2010 10:25 am
the snake racing high steer is a whole new casting. knuckle and steering arm. dont habve pics. have a look on the snake racign website. or i can take some tomorrow.
the tail shaft spacer is approx 10-11mm. out of a narrow track. but its got 2 sets of wholes. the other wholes are bigger so ill check if it mates up to a WT shaft for you. ill measure prop tomorrow.
and both the sierras are NT sorry
Post Posted: Mon Aug 09, 2010 10:27 am
Cool 8) i'll take the spacer then cheers, PM comin' your way! :wink:
Post Posted: Mon Aug 09, 2010 10:31 am
no worries
Post Posted: Tue Aug 10, 2010 1:36 am
bump. need room in the shed
Post Posted: Tue Aug 10, 2010 9:50 am
Wt dash cluster?
Post Posted: Tue Aug 10, 2010 9:58 am
Both vehicles areNT
Post Posted: Wed Aug 11, 2010 2:36 am
snakre racing high steer kit is same as this $950 from snake racing
Post Posted: Sat Aug 14, 2010 11:37 am
Bump
Post Posted: Sat Aug 14, 2010 11:54 am
Have you got a pair of doors and windscreen surround?
Post Posted: Sat Aug 14, 2010 12:28 pm
I have a cOuple of doors. Not real good though. No window surround
Post Posted: Tue Aug 17, 2010 4:27 am
price updates. still got lots of spares to get rid off. let me know what you need
Post Posted: Wed Aug 18, 2010 10:59 am
Do you have an ignition barrel and key for sierra/drover? Also do you have a timing belt cover for 1.3l in good cond?
Cheers Matt
1985 Holden Drover, soon to be modified
Post Posted: Wed Aug 18, 2010 1:05 pm
no barrel n keys. im pretty sure i have a timing cover. ill check tomorrow
Post Posted: Thu Sep 23, 2010 5:19 am
bump
Post Posted: Thu Sep 30, 2010 8:16 am
bummp
Post Posted: Thu Sep 30, 2010 9:09 am
Steering boxes in good order?
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Thu Sep 30, 2010 9:17 am
Yeah mate
Post Posted: Thu Sep 30, 2010 12:49 pm
how much posted for the snorkle to 3850 sale ,victoria :)
Sj80,31 claws, lift, winch, 6.5
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Fri Oct 15, 2010 8:04 pm
my steering's no good when the wheel is in the middle, would a steering box cure this as the steering is fine otherwise,
if so would you post to WA 6104?
cheers
89 Sierra (Crashed)
95 Vitara (Current)
Post Posted: Fri Oct 15, 2010 8:44 pm
cheers
Have you tried to tighten the adjusting screw on top of the box? and whats your steering damper like?
Users browsing this forum: No registered users and 28 guests
