It is currently Fri Oct 30, 2026 9:35 pm
Post Posted: Thu Aug 12, 2010 10:46 am
whent wheelin the other day with my bro , dad and uncle :D
when i got home noticed a leak coming from my front right hub right where it joins the diff :(
i think its the seals im no to flash with naming the parts
i'm fairly good mechanicly and think i can do it myself BUT just incase is there anything i should know or any tips
all feedback will be appreciated
thanks
Post Posted: Thu Aug 12, 2010 10:51 am
You axle seal's leaking into the swivel hub, you'll need swivel hub kit..
Post Posted: Thu Aug 12, 2010 10:57 am
there a bit of a bitch to do. there might be a trick to it but for me putting the rubber seal on, holding it there while aligning the felt seal and the two metal retainers was quite painful.
Post Posted: Thu Aug 12, 2010 10:59 am
You need to have your tongue to the left a bit.. :lol: :lol:
Post Posted: Thu Aug 12, 2010 11:01 am
gettin the kit shouldnt be a prop
me and my old man will be workin on it as we'v never done one before
if all else fails we'l get someon in but untill then
we'l give it a shot and put pics up later
1Hr 25 per side is my best effort. That includes cleaning parts, packing bearings by hand, and repacking CV joint. Also sealing all surfaces together with gasket goo :D
Felts are easy once you get the knack :wink:
Post Posted: Thu Aug 12, 2010 11:03 am
i did that, then i hit my head on the edge the flare, then i swore and eventually after that process was repeated quite a few times it was done :lol:
Post Posted: Thu Aug 12, 2010 11:06 am
There is a good wright up in here on doing them..
Not to hard to do, if you can do a wheel bearing you should be able to do that..
Post Posted: Thu Aug 12, 2010 11:13 am
sweet stuff im pretty confident in taking things apart and workin with it cheers
sounds like a go ahead to me
Post Posted: Thu Aug 12, 2010 11:26 am
taking it apart really isn't a problem, getting stuff together is a lot harder to get right ;) but you should be fine with this one, its not too difficult just fiddely
Post Posted: Thu Aug 12, 2010 6:59 pm
I don't know how many times i've done this, but i can pull it apart and get it back together, but the disk brake now hits the caliper holder.... me the retard :lol:
also, it takes me 30mins to pack and finish front wheel bearings 8)
Post Posted: Mon Aug 16, 2010 9:49 am
just wondering what's an average price you'd pay for a swivel front hub kit, and where would you get it from
Thanks
Post Posted: Mon Aug 16, 2010 10:22 am
ebay, bout $80. more for more seals and stuff
Users browsing this forum: Google [Bot] and 133 guests
