| Author |
Message |
sbbunno
Joined: Mon Mar 08, 2010 10:30 pm Posts: 420 Location: Perth/bunbury
 Posted: Thu Aug 12, 2010 10:46 am |
whent wheelin the other day with my bro , dad and uncle
when i got home noticed a leak coming from my front right hub right where it joins the diff
i think its the seals im no to flash with naming the parts
i'm fairly good mechanicly and think i can do it myself BUT just incase is there anything i should know or any tips
all feedback will be appreciated
thanks
steak_knife
 Posted: Thu Aug 12, 2010 10:51 am |
You axle seal's leaking into the swivel hub, you'll need swivel hub kit..
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Thu Aug 12, 2010 10:57 am |
there a bit of a bitch to do. there might be a trick to it but for me putting the rubber seal on, holding it there while aligning the felt seal and the two metal retainers was quite painful.
steak_knife
 Posted: Thu Aug 12, 2010 10:59 am |
Zook_Fan wrote: there a bit of a bitch to do. there might be a trick to it but for me putting the rubber seal on, holding it there while aligning the felt seal and the two metal retainers was quite painful.
You need to have your tongue to the left a bit..
sbbunno
 Posted: Thu Aug 12, 2010 11:01 am |
gettin the kit shouldnt be a prop
me and my old man will be workin on it as we'v never done one before
if all else fails we'l get someon in but untill then
we'l give it a shot and put pics up later
Fatzook
1Hr 25 per side is my best effort. That includes cleaning parts, packing bearings by hand, and repacking CV joint. Also sealing all surfaces together with gasket goo
Felts are easy once you get the knack
Zook_Fan
 Posted: Thu Aug 12, 2010 11:03 am |
i did that, then i hit my head on the edge the flare, then i swore and eventually after that process was repeated quite a few times it was done
steak_knife
 Posted: Thu Aug 12, 2010 11:06 am |
sbbunno wrote: gettin the kit shouldnt be a prop me and my old man will be workin on it as we'v never done one before if all else fails we'l get someon in but untill then we'l give it a shot and put pics up later
There is a good wright up in here on doing them..
Not to hard to do, if you can do a wheel bearing you should be able to do that..
sbbunno
 Posted: Thu Aug 12, 2010 11:13 am |
sweet stuff im pretty confident in taking things apart and workin with it cheers
sounds like a go ahead to me
Zook_Fan
 Posted: Thu Aug 12, 2010 11:26 am |
taking it apart really isn't a problem, getting stuff together is a lot harder to get right  but you should be fine with this one, its not too difficult just fiddely
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Thu Aug 12, 2010 6:59 pm |
I don't know how many times i've done this, but i can pull it apart and get it back together, but the disk brake now hits the caliper holder.... me the retard
also, it takes me 30mins to pack and finish front wheel bearings
Tonka4
Joined: Thu Jun 03, 2010 1:20 pm Posts: 25 Location: Central Coast NSW
 Posted: Mon Aug 16, 2010 9:49 am |
just wondering what's an average price you'd pay for a swivel front hub kit, and where would you get it from
Thanks
Zook_Fan
 Posted: Mon Aug 16, 2010 10:22 am |
ebay, bout $80. more for more seals and stuff
