Was putting some springs in the rear the other day and to get enough drop to get the spring out, I removed a small bracket thing holding the brake line to the control arm (or whatever it's called). Is it ok to keep this thing out to allow a longer extension or is it there for a good reason?
_________________ The LWB From 1993. Poetry in motion
i just finished putting my kings springs in and vt shocks just flexed it up and brake line was fine still had a curl in it had about 40mm between spring and spring seat have to zip tie them up or make some clamps
_________________ lseries 2" body lift king springs 27" boots and a
Posted: Sat Aug 14, 2010 4:22 am
it's the hand brake cable that's attached to both of the rear arms on the vitara's.
i made up small extensions for the bracket on the arms & got a heap of slack by moving the clamps that hold the cable up on the crossmember where the A arm mounts.
Users browsing this forum: Google [Bot] and 714 guests
