It is currently Thu Oct 29, 2026 8:06 pm
Post Posted: Mon Aug 16, 2010 9:58 am
ok im going to go pick up my OME springs i ordered im going to do RUF with them now i have a question iv been seeing alot of people extented there Chasie out ...but iv also herd that u could just re drill ur rear hangers ..can anyone explane whats the best way to do this set up ...thanks
Post Posted: Mon Aug 16, 2010 10:10 am
Try this
http://auszookers.com/index.php?name=Fo ... pic&t=4269
I Do Shade Sails & Roller Blinds, ect
Post Posted: Mon Aug 16, 2010 10:59 am
Geepee wrote:
that is a great example of a RUF set up but it all depends how much work you want to do, theres a few threads laying around for each one, extending chasis usually involves moving the diff forwards which can help with bigger wheel clearance but is also more work
try these build threads
Moph
want33s
alex
Vehicle: 93 Sierra
Post Posted: Mon Aug 16, 2010 11:02 am
Mine's in my sig to help your search. Redrilling your rear hangers works but doesn't give as much tweakability due to the limitations on where you can put your new mount.
Post Posted: Mon Aug 16, 2010 11:51 am
so moph u have re drilled ur mounts ?
or have u moved them now
Vehicle: 93 Sierra
Post Posted: Mon Aug 16, 2010 11:52 am
New hanger plates bolted to the sides of the cut-down original mounts.
Post Posted: Mon Aug 16, 2010 12:03 pm
so when u took the photo did u have the new plates done ?
Post Posted: Fri Sep 03, 2010 7:47 am
what exactly is involed in doing rear up front?
and whats the advantage you gain?
Post Posted: Fri Sep 03, 2010 8:32 am
RUF allows longer springs to be fitted to the front, thus allows more wheel travel...
If you extend the chassis and move the front mount forwards, you move the front diff forwards and increase the distance from the firewall to the tyre, so you can fit significantly bigger tyres.
Its one of the more effective but not too expensive upgrades you can do to your suspension.
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Fri Sep 03, 2010 9:37 am
wouldnt that look cock eyed due to the wheel arch etc.?
Post Posted: Fri Sep 03, 2010 10:24 am
you tell me full ruf (chassis ext) no redrilling rear mount
Post Posted: Sat Sep 04, 2010 7:05 am
i guess not then. that things a bit of a rig. spoa?
Post Posted: Sat Sep 04, 2010 7:07 am
no spua
Post Posted: Sat Sep 04, 2010 8:21 am
ajsr wrote:
no spua
Your car's yummy.. 8)
Users browsing this forum: fordem and 133 guests
