It is currently Fri Oct 30, 2026 4:29 pm
Post Posted: Fri Sep 03, 2010 7:25 pm
my 95 sierra has a pretty noisey whine to it not that bad under accelration but terrible under decceleration sounds sort of metalic noise but it goes away when i apply the clutch would this be my gear box it has 227 000 kms on it
thanks
Vehicle: '94 suzuki maruti
Post Posted: Fri Sep 03, 2010 9:37 pm
is the noise consistent with the engine revs or car speed? as in, if you change a gear does it become slightly louder or quieter, or the same regardless of the RPM?
i would be checking oil levels first... or try replacing oil completely. might at least lessen the noise...
Vehicle: LJ20 LJ50
Post Posted: Fri Sep 03, 2010 9:38 pm
probably transfer case noise. very common
Camels have nice toes
Post Posted: Sat Sep 04, 2010 2:33 am
same noise regardless of the revs or gears
Post Posted: Sat Sep 04, 2010 3:03 am
__________________
watch free movies online
Post Posted: Sat Sep 04, 2010 3:06 am
gear box oil is fine done it a couple of months ago will check tranfer oil
Post Posted: Sat Sep 04, 2010 3:16 am
That mean's nothing if you've been through water, would pay to at least check it..
Post Posted: Sat Sep 04, 2010 4:12 am
i haven't been through any water just checked transfer oil it seemed a little low (had to put finger in and around the filler hole to feel any oil ) i dropped it and put some new stuff in there will have to c how it goes now.when i tipped the old oil into a 1.5ltr bottle it was under half way up so guess it had around 600ml-700ml of oil in it so would this have any thing to do with the noise or could it be a bearing related problem
Users browsing this forum: No registered users and 342 guests
