It is currently Sat Oct 31, 2026 12:38 am
Vehicle: Sierra
Post Posted: Sat Sep 04, 2010 11:31 am
Just wondering what the recommended oil for a 1990 1.3L sierra is. My sierra had no owners manual and i have searched but somehow can't find the actual recommended oil grade. I've run HPR15 which is 15w60. I was thinking of running HPR10 instead atleast for winter?
Post Posted: Sat Sep 04, 2010 11:35 am
personally I think 10w40 is the right grade for a 1.3 or 1.6
Vehicle: Sierra
Post Posted: Sat Sep 04, 2010 11:41 am
Thanks ajsr
HPR10 would be ideal then. Out of curiousity do you know what suzuki recommends?
Vehicle: Suzuki
Post Posted: Sat Sep 04, 2010 12:57 pm
I got HPR30 in mine, runs ok I believe. Im no oil expert.
Post Posted: Sat Sep 04, 2010 3:43 pm
mika wrote:
Thanks ajsr
The owner's manual will have a chart which shows several grades of oil being used over different temperature ranges. I've never looked at the Sierra manual, but if it's the G13 engine, the recommended oil will be a 10w30 from below 0*C upto around 30*C.
If you're in a climate that will see temperatures above that regularly - like I am - you can use a 10w40, if you're in a climate that sees lower temperatures you can go the other way and use a 5w30.
Vehicle: Sierra
Post Posted: Mon Sep 06, 2010 7:17 am
thanks guys,
have been without power hence why i have been slow to respond. I'll just run the HPR10 which is 10w-40 (or 10w-50 with their claimed plus 10 crap)
thanks fordem, just the info i've been looking for
Users browsing this forum: Google [Bot] and 385 guests
