| Author |
Message |
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Mon Sep 13, 2010 8:03 pm |
Just went to start redzook, and the after the first go, something started spinning real fast, guessing it is the starter motor, but while it is retracted.
I had to disconnect the battery to get it to stop.
So (because my multimeter is at work) would it be the solenoid that is stuck, or a relay somewhere that is the problem?
Last edited by lump_a_charcoal on Mon Sep 13, 2010 8:18 pm, edited 1 time in total.
royce
 Posted: Mon Sep 13, 2010 8:17 pm |
pull the little wire off the solendoid and if it keeps going its probably the solenoid
lump_a_charcoal
 Posted: Mon Sep 13, 2010 8:23 pm |
lump_a_charcoal
 Posted: Mon Sep 13, 2010 8:31 pm |
Yep, the noid.
Thanks Rice.
royce
 Posted: Mon Sep 13, 2010 8:36 pm |
big hammer
lump_a_charcoal
 Posted: Mon Sep 13, 2010 8:38 pm |
Tried that, still stuck on.
Think I need a new one.
lump_a_charcoal
 Posted: Mon Sep 13, 2010 8:43 pm |
Is it easier to replace the noid on the starter in the car, or to pull the whole thing out?
royce
 Posted: Mon Sep 13, 2010 8:45 pm |
nah you need to pull it out cause there is a fork and slidy thingy in there
PJ.zook
Joined: Sat Oct 24, 2009 10:30 pm Posts: 845 Location: Melbourne
 Posted: Mon Sep 13, 2010 8:54 pm |
If the starter stopped spinning when you pulled the little signal wire off, then its most likely not the solenoid, as thats just a signal wire. If the solenoid was jammed then it would remain spinning, regardless of what the signal wire is doing. Its most likely something else back down the line, which really could only be your ignition barrel.
lump_a_charcoal
 Posted: Mon Sep 13, 2010 8:58 pm |
It stopped spinning when I pulled the battery cable off.
I then disconnected the trigger, reconnected the battery cable, and it started spinning again.
It is the noid.
PJ.zook
 Posted: Mon Sep 13, 2010 9:09 pm |
Sweet as. Its weird that just the motor spins without 'throwing out', could be a stuck relay with broken fork, or cracked solenoid causing internal short.
lump_a_charcoal
 Posted: Mon Sep 13, 2010 9:13 pm |
I was thinking they may be designed like that - You don't want it getting stuck on and throwing out at the same time...
lump_a_charcoal
 Posted: Mon Sep 13, 2010 9:51 pm |
I rang up my local parts mongers, they said they have a universal noid, does this sound right? Is it a common part?
royce
 Posted: Mon Sep 13, 2010 10:37 pm |
hell no!!!
I doubt anyone would list it as a seperate part, would all be new starters only
BlueSuzy
 Posted: Mon Sep 13, 2010 11:13 pm |
Lumpa, So it definately the solinoid??
If it is, you can get another one from a wreckers. I know some lancers have the same starter as the sierra's. but most likely wouldnt want you to pull them apart..
lump_a_charcoal
 Posted: Tue Sep 14, 2010 1:12 am |
I took another spare to my autolecky, and he tested and cleaned it up for me, so I should be able to just put it on and hope.
lump_a_charcoal
 Posted: Tue Sep 14, 2010 2:14 am |
FAAARRRKKKKKKK!!!!!!!
The botom bolt is so tight I have almost rounded it, and now it is raining!
BlueSuzy
 Posted: Tue Sep 14, 2010 2:17 am |
They are a pita sometimes
Lucky i had oil leaks, No need for wd40!
PJ.zook
 Posted: Tue Sep 14, 2010 2:25 am |
You definately can get solenoids separately. Ive gotten one for mine and so has Jayson. You have to be careful though, the parts catalogue isnt exactly clear so its best to bring in the solenoid to compare.
lump_a_charcoal
 Posted: Tue Sep 14, 2010 2:34 am |
Yeah Autoone have them for $15 apparently.
madladBryan
Joined: Tue Sep 14, 2010 8:26 am Posts: 3 Location: Blacktown
 Posted: Tue Sep 14, 2010 8:46 am |
lump_a_charcoal wrote: Just went to start redzook, and the after the first go, something started spinning real fast, guessing it is the starter motor, but while it is retracted. I had to disconnect the battery to get it to stop.
[quote="hit it with sledgehammer
steak_knife
 Posted: Tue Sep 14, 2010 8:54 am |
royce wrote: hell no!!!
 My lecy does!!
