It is currently Sun Nov 01, 2026 5:31 am
Post Posted: Tue Sep 14, 2010 10:18 am
G'day
do you know where i can get some crush tubes from? I need few for chassis. 10-14mm OD. as usually is to much to ask for in bunnings, they have 16 ODmm steel pipes and 12mm OD aluminium ones. I've check some steel shops but they don't have such a small diameter pipes. copper and aluminium is probably to soft
cheers
Chris
Post Posted: Tue Sep 14, 2010 10:20 am
whats wrong with 16mm steel pipe, use a bigger washer
Post Posted: Tue Sep 14, 2010 10:44 am
How much did u need chris? Im using tube to suit M12 bolts. 1.7mmthk wall
Post Posted: Tue Sep 14, 2010 12:30 pm
i use rhs for mine
20x20x1.6 from memory. but that is in the end of the chassis for bar mounts
Post Posted: Tue Sep 14, 2010 2:40 pm
PM send
Post Posted: Wed Sep 15, 2010 9:09 am
try a hydraulics shop like enzed or pirtek.
Post Posted: Wed Sep 15, 2010 11:00 pm
Thats a good idea!
Post Posted: Thu Sep 16, 2010 1:39 am
Thats a good idea!
most will carry seamless tube, which cost alot more. not sure if you get it per metre or not.
navara on 33s. hopfully rear air locker soon
Post Posted: Thu Sep 16, 2010 12:38 pm
thanks guys, I'll keep looking around.
Post Posted: Thu Sep 16, 2010 8:53 pm
Yeh as others have said, just use steel pipe. I found some a little larger than the bolt, cut them so they are a snug fit in the rail, then shoved the bolts thru and tightened.
Post Posted: Fri Sep 17, 2010 10:35 am
brendan wrote:
Thats a good idea!
They should sell it in what ever length you want. 12mm bolt is a neat fit in 16mm x 1.6 hydraulic tube.
Post Posted: Sun Sep 19, 2010 7:02 am
what is a crush tube?
are you talking about the tube that goes in the centre of the rubber mounts?
Post Posted: Sun Sep 19, 2010 8:07 am
yeah pretty much. same concept, use to stop the chassie from being pulled in.
got a question, do you have to weld them in?
Post Posted: Sun Sep 19, 2010 8:28 am
yes
Post Posted: Sun Sep 19, 2010 8:52 am
No you dont have to weld them in
Post Posted: Sun Sep 19, 2010 8:59 am
whats to stop them moving in the box section and enlargeing the holes then?
I'll keep welding mine pj :wink:
Post Posted: Sun Sep 19, 2010 8:00 pm
They shouldnt really move at all should they? Mine are still as tight/solid as when I put them in.
What steel did you use out of interest?
I should then clarify, SHOULD you weld them in, yes apparently its safer.
Do you HAVE TO weld them in, no.
Users browsing this forum: No registered users and 108 guests
