It is currently Fri Oct 30, 2026 9:13 pm
Post Posted: Thu Sep 23, 2010 5:38 am
Does anyone know if there are long range fuel tanks available for 92 swb vitaras? also fuel tank protection plates? with the help of a few rocks i have reduced the fuel capacity of mine...
Post Posted: Thu Sep 23, 2010 6:06 am
Afaik they dont make them any more witch sucks cause i want one aswell :evil:
For a bash plate have a look in here TSOR
Post Posted: Thu Sep 23, 2010 6:14 am
Polar_Bear has one in his "resto" vit I think it's a long ranger, maybe give them a buzz to see if they'll make one for you.
Post Posted: Thu Sep 23, 2010 6:16 am
The white one or the new one :?
Its not on there web site, they only list ones for sierras :roll:
Post Posted: Thu Sep 23, 2010 6:20 am
the white one... aka the Coona or the UFP (Un Finished Project)
Post Posted: Thu Sep 23, 2010 6:21 am
might just have to knock somethin up myself. should be a bit of fun, ill have a crack at a cut-and-shut job with another one the same
Post Posted: Thu Sep 23, 2010 6:24 am
Brown davis :wink:
http://www.browndavis.com.au/navtankmodels.html#suzuki
But i'd say when you hear the costs of long range tanks you'll change ya mind!
Vehicle: SJ50 hardtop!
Post Posted: Thu Sep 23, 2010 8:29 am
Chop wrote:
Brown davis :wink:
Yeah, but at least you know what your getting is a quality product.
NT SJ50
Post Posted: Thu Sep 23, 2010 9:25 am
i had a look at Long range tanks, for an additional 20L, you had to pay $900ish.
or you could get a 20L jerry can for roughly $20 and get the same thing. sure it takes up a bit off space, but i think its worth it for save $900.
Mitch
Vehicle: 2004 SQ625 GV
Post Posted: Thu Sep 23, 2010 10:10 am
Does any one know if the older 5 door vit tanks are the same as a GV SQ625? I would like to get a LR tank and they have one listed for the older vits
Post Posted: Thu Sep 23, 2010 11:20 am
No.
AFAIK the SQ tanks are a supid looking thing with weird mounts ets.
The SE416W LWb tanks will fit between the rails, but are very shallow, and very long and wide, so they take up heaps of space without giving much capacity. (55L??)
The SV tanks will also fit under an SQ, but they will be the same shape roughly and the same capacity.( mounts would need to be fabricated to fit any of these tanks to an SQ.
Post Posted: Thu Sep 23, 2010 11:27 am
im with the jerry can option and maybe a jerry holder out back.....but im a tight ass.
Post Posted: Thu Sep 23, 2010 11:52 am
No.
I will stick with jerry's then :(
Post Posted: Thu Sep 23, 2010 12:10 pm
Sorry, just to clarify.
With some custom mounts you may be able to get an SE416W long range tank under an SQ LWB. But it will most definately foul on the rear axle of an SQ SWB.
I'd get some accurate measurements from the manufacturer before you do anything else.
Post Posted: Thu Sep 23, 2010 12:13 pm
If you can manufacture the mounts PROPERLY yourself, then it may be a viable option. Otherwise this will cost you a truck load for nothing more than a $20 jerry can offers.
Post Posted: Thu Sep 23, 2010 7:41 pm
I used to weld tanks for brown davis, trust me you cant just knock one up without dramas.
I also vote jerry can
Users browsing this forum: No registered users and 411 guests
