It is currently Mon Oct 19, 2026 7:31 am
Post Posted: Tue Apr 01, 2008 5:07 pm
had a mate point out to me the other day that my reverse lights come on in 4th gear, i looked at him and said 'bullshit' he said nah ill show ya. he got in switched the car in put it in 4th and WTF? reverse lights are on 8O
whats the go here, can anyone help me cause fucked if i know whats goin on?
Grizz
Vitara gone, tis no more. replaced by a 98 XH Falc
Post Posted: Tue Apr 01, 2008 5:20 pm
what about 5th?
Post Posted: Tue Apr 01, 2008 5:25 pm
Has he had the tranny out recently?
Sounds like he's got the connector for the reverse switch connected to the 4th gear switch.
I wonder if the EGR kicks in when he's reversing :P
Post Posted: Tue Apr 01, 2008 5:26 pm
thats what I was thinking, though do vits have seperate switches for 4th and 5th?
Post Posted: Tue Apr 01, 2008 5:50 pm
NFI, didn't realise it was a Vit. Fairly likely though.
Post Posted: Tue Apr 01, 2008 6:13 pm
Sounds like the switch is picking up the fourth and reverse gates, might need adjusting? Unless something has broken or is heavily worn.
Post Posted: Tue Apr 01, 2008 7:39 pm
I'm back
Royce: not in 5th
Damo: any idea where these switches are and i did pull gear box out to replace clutch
ScrawnC:
what would i need to adjust?
Post Posted: Tue Apr 01, 2008 8:58 pm
On the Sierra they are on the top of the 'box between the shifter and the bellhousing, I can only assume that on the Vit they are going to be in a similar spot. Might be a bugger of a spot to get to?
Post Posted: Tue Apr 01, 2008 9:31 pm
Damo spot on with the friggin switchs found them..... well i thinks its them there just blobs back me engines got a leak but thats another thread....... i'll ave a look tomorra mornin when eveything is cold and i've got a few more hours to buggerise around
Post Posted: Tue Apr 01, 2008 9:53 pm
Good idea, i would probably be just leaning on the guard, staring at it with beer in hand :oops:
Post Posted: Tue Apr 01, 2008 10:12 pm
The_GRIZZ wrote:
ScrawnC:
I'm just guessing here as I have never played with these before but some switches are threaded in with a lock nut. Just a guess as fourth and reverse gates are close together. Hopefully you won't be pulling the box out again!! You might be able to pull out the gear lever and see down inside too.
Post Posted: Tue Apr 01, 2008 11:03 pm
Any body got somethin that has what switch is what?
Post Posted: Wed Apr 02, 2008 12:52 am
There should only be 2 switches? Just unplug them & swap the plugs & you're done. Easy to test if you've got the right plugs.
Post Posted: Wed Apr 02, 2008 1:20 am
Okay that means one of them is just a blob of somethin :lol:
Post Posted: Wed Apr 02, 2008 8:04 pm
Fixxed :woohoo:
Post Posted: Wed Apr 02, 2008 8:08 pm
What was the problem?
Post Posted: Wed Apr 02, 2008 9:34 pm
Switches were ass-about
Post Posted: Wed Apr 02, 2008 10:07 pm
Nice easy fix then, sweet!
Post Posted: Thu Apr 03, 2008 10:41 am
So exactly what is the purpose of the 4th gear switch??? :?
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Thu Apr 03, 2008 3:38 pm
Dunno, i'll flick through the manual later it may say somethin if not then WhoTF knows
Post Posted: Thu Apr 03, 2008 6:33 pm
The 5th gear switch I have been told in called a " Top over Top" meaning that when taken from 4th to 5th it goes into a sort of overdrive and tells the computer it will not need as much fuel.
As I say this is just what I have been told....
Steve W
Post Posted: Thu Apr 03, 2008 7:18 pm
I'm pretty sure its to activate the EGR (exhaust gas recycle), which allows some of the exhaust gas to be vented into the inlet manifold. It's an emissions thing.
Post Posted: Thu Apr 03, 2008 9:40 pm
Westie there is a HUGE hole in that theary mine no have 'putter mine have carby.
as i you read this i am going through my manual to see what it says
Post Posted: Thu Apr 03, 2008 10:03 pm
Well aparently the two switches i swapped round don't exsist in the manual it only shows the 5th gear switch witch is a lot further back under the car than what i was playing with.....so...............meh. if anyone does find out what they are post it up here, i know one is a reverse sensor but the other one is what puzzles me :? msybe i have a crossbred mungle of a car.
(useless fuggin manual aaaaaaarrrrrggggghhhhh)
Post Posted: Fri Apr 04, 2008 12:25 am
The late late 95's on have 5 switches on them
Steve W
Post Posted: Fri Apr 04, 2008 12:39 am
heh mine 89
Post Posted: Fri Apr 04, 2008 1:21 am
Hey The Trolly is a 89 also
Steve W
Post Posted: Fri Apr 04, 2008 5:16 pm
cool i'm gonna hijack my own thread here. Westie did yours ever have a problem with engine power
Users browsing this forum: No registered users and 268 guests
