It is currently Tue Oct 20, 2026 3:23 pm
Vehicle: 75 Cruiser
Post Posted: Tue Mar 18, 2008 4:22 pm
i had a heap of mud in my tank, it clogged up the fool filter and the car was running like crap.
I took the tank out and cleaned it out and looks clean now.
I put a new fool filter on.
I blew the lines out with an air gun.
I removed the fool line from the carby and cranked the engine over so the petrol was pumping out the line.
I removed the drain bung thing in the carby and emptied it.
I sprayed carby cleaner everywhere in the carby.
It now runs a lot better, but it's a bit inconsistant at idle. The revs go up and down slightly.
any ideas? It may still have crap in the carby i guess.
Post Posted: Tue Mar 18, 2008 4:26 pm
airblower down the jets :)
and get a better filter if it let it through
Vehicle: 75 Cruiser
Post Posted: Tue Mar 18, 2008 4:38 pm
i bought a $8 one for Suzukis, instead of the $2 generic ones, and it's perfectly clear, so you can see inside, bling eh!
I'll attack it again today.
Could the Coil/spark plug leads/spark plugs effect the idle like that also?
It's the same as when you have a weirdo vacuum issue with the carby.
It just goes up and down a little.
Post Posted: Tue Mar 18, 2008 4:40 pm
they could make it rough but if they were ok before I dont think it would be the prob
might be a dodgy vacuum hose somewhere that got bumped too, spray some crc or carb cleaner around the intake while idling and if it changes theres your leak
Vehicle: 75 Cruiser
Post Posted: Wed Mar 19, 2008 3:44 pm
i sprayed carby cleaner everywhere and blew it out again. It was still a little rough so changed the leads and after being electricuted a few times it seemed to be ok. So not exactly sure what the problem was or if it's definatley fixed, will find out this weekend :)
Post Posted: Wed Mar 19, 2008 9:24 pm
When mines not runnin right i take the air cleaner off the top of the carby then give it some revs ands stick your hand over the top of the carby and that cleans out all your jets!
Works every time the mechanic over the road showed me and has got me out of the sh!T on more then 1 occasion! :wink:
back in a built sierra!
Vehicle: 75 Cruiser
Post Posted: Tue Mar 25, 2008 10:54 am
after heaps of trouble on the weekend with crap in the carby i've learnt how to pull it all apart and clean the idle jet, it kept becoming clogged so had to keep cleaning it, it was getting better by the end of the weekend.
Post Posted: Tue Mar 25, 2008 12:08 pm
You need to pull the float bowl right off and clean it out. Then pull the other jets out and the emulsion tube too. Probably plenty of crap floating around still.
Vehicle: 75 Cruiser
Post Posted: Tue Mar 25, 2008 12:13 pm
yeap, did all that too :D
Post Posted: Wed Mar 26, 2008 11:29 am
So do you run a second filter between the fuel pump and carb? Also check the state of your carb gaskets. These deteriorate and clog the idle jet and the emulsion tube fairly quickly. If you do go for a rebuild kit check the quality of the gaskets as well ie check that there isnt any fibers hanging out everywhere, or just make some outta the ole cornflakes box :wink: .
Cheers Dan
Vehicle: 75 Cruiser
Post Posted: Wed Mar 26, 2008 5:29 pm
I did take a spare fool filter with me, so we stuck in betweem the fool pump and carby, it stayed pretty clean throughout the weekends driving.
We did make another gasket out of thin cardboard and gasket glue goop stuff. We sprayed a fair bit of carby cleaner throughout the carby so i am assuming that it's still stuff in the carby that is loosening up and blocking the idle jet because that was the only issue by the end of the weekend.
I'll give it a few runs and cleans over the next few weeks anyway.
Post Posted: Wed Mar 26, 2008 5:33 pm
probably the gasket goo, never put anything on carby gaskets
Vehicle: 75 Cruiser
Post Posted: Wed Mar 26, 2008 5:36 pm
ahhh ooo ok :?
Post Posted: Wed Mar 26, 2008 5:52 pm
see if the carby guy at kippa ring will dip a pulled apart carby for you
Vehicle: 75 Cruiser
Post Posted: Sun Apr 13, 2008 11:07 pm
Today i pulled the carby apart and cleaned it all out, but while i was doing that i found another carby in the shed and pulled it apart and removed all the bits that attach to the outside, then whacked it on and it ran awesome, had down to 500 rpm and was running very nicely.
Post Posted: Sun Apr 13, 2008 11:26 pm
Another quiet day at Steve's place aye? :lol:
Damn, wish I had those. The list of things I need to do to mine grows longer every time I look at it!!
Post Posted: Mon Apr 14, 2008 3:42 am
so you ripped off all choke assy etc? no issues with clogging up yet?
Vehicle: 75 Cruiser
Post Posted: Mon Apr 14, 2008 10:38 am
yeah there's no choke now, and no idle up with headlights switch, although royce reckons i should stick one on and have an in cab switch for idle up.
seem to run pretty good. I haven't actually driven it anywhere yet though.
I will take my old complete carby out with me as a back i think :lol:
Vehicle: Clown Car..
Post Posted: Tue Apr 15, 2008 12:38 am
do you know what crbie it is? 4k rolla ones are apperently pretty good.. yet to try.. but got one in case..
Had the problem of mine not idling or running right.. so a can of carbie cleaner, air filter off, sprayed the fuck out of atll the little jets and pipe lines, bit of a rev here and there, then installed a fuel filter after the pump but before the carb. and havnt had an issue since.. Rekcon this is a HUGE cause of peoples carb dramas..
Rolla 4k carb.
Vehicle: 75 Cruiser
Post Posted: Tue Apr 15, 2008 10:10 am
gees that looks very similar to a sierra 1.3 carby.
I just used the standard 1.3 carby.
Post Posted: Wed Apr 16, 2008 12:46 am
bolt on replacement.. manual choke.. min. vac lines..
Its ALOT cleaner now than the pics.. sorry!
4k corolla...cheap, EASY swap(apperently)..
Users browsing this forum: No registered users and 189 guests
