It is currently Wed Nov 04, 2026 12:12 am
Vehicle: SJ50 hardtop!
Post Posted: Tue Jul 06, 2010 4:30 am
Can anyone show me some pictures of how they modified the front bumper on their vitara to accomodate a 2" body lift?
I was going to just use some flat bar and just move the brackets up, but i'd have to move the brackets out and I don't wanna pissfart around like that.
NT SJ50
Post Posted: Tue Jul 06, 2010 5:53 am
put a custom bullbar on it instead. looks better, adds protection and a place for a winch, spotties, aerials
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Tue Jul 06, 2010 6:13 am
I'd like to, but I can't justify it at the moment.
I need all the coin I can save for Sydney.
NT SJ50
Vehicle: LWB Sierra & XL7
Post Posted: Tue Jul 06, 2010 6:46 am
My bullbar has been chopped, moved up and re-welded.
'92 Vitara & Camper trailer
Post Posted: Tue Jul 06, 2010 7:01 am
i just used 2" box section & flat bar to go back to the mounts...
have a search for posts from ninjamoses, i think he's posted some pics during his build up or body lift.
Post Posted: Tue Jul 06, 2010 8:22 am
my front bar is custom, but rear bar ive used 2x1 in box, and flat, worked fine, even taken a nudge from a cruiser
Post Posted: Thu Jul 08, 2010 2:14 pm
Still interested on the front lift.
Seems the mounting is different between the 2L vits and the 1.6s
NT SJ50
Post Posted: Thu Jul 08, 2010 9:23 pm
mines not a 2L its 1.6 carby, but from how my front bar mounts, i reckon if you take the inner bumper out and get a couple of tags welded to it with new holes, could work
Post Posted: Sun Dec 12, 2010 9:02 am
i got given some 40x40 square tubing today, and yes i no its not 50mm like the body lift but for now it will do.
here is a pic of mine with the bumper off, can someone please identify where i put the blocks? i have circled the mounts in green.
there are 4 screws that go just below the door, but they are on the body. there are 3 on the bottom but i cant see how i could use the blocks on them, as ur not screwing them down but more up, and u cant put the blocks above them as it just would work.
thanks
Mitch
Post Posted: Sun Dec 12, 2010 9:06 am
the RHS (really hard stel) goes between the chassis & the inner bumper frame, then the bumper goes over that.
got any better pics or ones with out crop circles?
Post Posted: Sun Dec 12, 2010 9:10 am
oh yeah, i get what ur saying now. i dont have any other pics but i can give u the original.
looking at it now, that makes a lot more sense and doesnt sounds that hard to do. i can prob find 10mm (5mm either side) worth of washers to make it 50mm.
p.s, u have a pm, but please disregard it.
Post Posted: Sun Dec 12, 2010 9:25 am
1/2 arsed pm sent back :wink:
there should be 3 bolts along the top & the 2 down the bottom might need to straighten out the dog leg bend & screw it down with some self tappers.
Post Posted: Sun Dec 12, 2010 9:39 am
do u mean 4 and 3? on mine there are 4 and 3, not 3 and 2 as shown in the picture. with the bottom mounts, once they are bent out do u then put a spacer ontop?
Mitch
Post Posted: Sun Dec 12, 2010 9:56 am
the circles you have drawn are for the bumper to screw onto the bumper frame & to the body, am i right when you put the bumper back on it had to stretch up to get to those 4 screws?
what you need to do is space the bumper frame up 50mm, there should be 3 bolts holding the frame to the chassis up the top & 2 on the bottom. when you pull the bumper off it should be pretty clear what needs to be done where.... also it's very different to the SV420s & i've never looked at the back of SE416 that close.
also, i would just grab a length of 50mm RHS & cut it up rather than putting washers to space it up 10mm as there won't be much surface area with the washers & it will probably end up fatiguing the RHS or even worse the chassis.
Post Posted: Sun Dec 12, 2010 10:49 am
yea thats right, from the side you can see that the top of the bumper is on a slight angle to get to the holes,
oh rightio, thanks for that info. i never got a good chance to have a look at that rear bumper support as i was busy doing the front when the other put it back on.
yeah im going to try and see what i can get in the next few days and hopefully have a crack at it this w.e, hopefully its not to pricey.
thanks for you help
Mitch
Users browsing this forum: No registered users and 74 guests
