It is currently Tue Nov 03, 2026 12:05 pm
Post Posted: Sun Dec 12, 2010 7:41 am
hey every one can u put a sr20de in a 92 wt swb soft top zook? i mean legaly? can it b plated in queensland? what do i need to do to make it legal? i have tried searching but no luck,
Vehicle: LJ20 LJ50
Post Posted: Sun Dec 12, 2010 7:51 am
YES
NO its to big
if you really want to try talk to an engineer who may sign off on it but no I don't know of any that will
Camels have nice toes
http://www.auszookers.com/index.php?nam ... light=sr20
Post Posted: Sun Dec 12, 2010 9:12 am
so it can not b mod plated? what about ca18de?
Post Posted: Sun Dec 12, 2010 9:19 am
there's a idea, ask an engineer
Post Posted: Sun Dec 12, 2010 7:23 pm
Who in brisbane?
Post Posted: Sun Dec 12, 2010 7:38 pm
boost=money wrote:
Who in brisbane?
Call QLD transport Modifications division. They have a list of engineers.
Post Posted: Sun Dec 12, 2010 7:46 pm
yeh, a few on here have done it.
Post Posted: Sun Dec 12, 2010 8:53 pm
If your in qld you arnt allowed to have a modified car without special approval on your p's. Just like you can't have a v8 or turbo without approval.
So your bugged even if you are able to mod plate it.
Sorry to bring the ba news
Post Posted: Sun Dec 12, 2010 11:02 pm
where did he mention being on his p's?
Ca18 has been done with approval not sure about the sr though. It's alot of work you need to move the transfer back 150mm or there abouts then new drive shafts etc you would end up with a very short rear shaft. Doing it in a lwb would be a much better option.
Post Posted: Sun Dec 12, 2010 11:39 pm
I'm not sure if QLD is on the NCOP VSB14 legislation - but if they are, you can legally put a ca18det into a Suzuki as long as you upgrade the braking system to match (as in disc rear) that of the donor vehicle. I am currently in the process of engineering my Ca18det LWB. The VSB14 document states: for a passenger car between 800kg and 1100kg you can upgrade the engines capacity 2.75 times the cars weight : eg: 1000 x 2.75 = 2750cc . However it also states there is no limit for 4wd or commercial vehicles 8) .
The legislation isnt really that bad - the only thing it doesnt allow you to do is go over 6inches total lift and 50mm in the tyres.
Search google for the document - its big!
Post Posted: Mon Dec 13, 2010 1:01 am
Woops I spotted b plated and got confused with p plate for some reason.
( it was early)
Edit: nope it was late either way i was sleepy as :lol:
Post Posted: Mon Dec 13, 2010 1:12 am
im doing a j20 and have some one to do the blue plate. so 2l can be done. You need to do brake upgrades though. not 100% sure about the sr though
Post Posted: Mon Dec 13, 2010 1:29 am
Ok so sounds like I can do it, any one know the GVM of a 91 wt?
And I'm not on my p's lol that was years ago. My first car was a v8. Lol
Post Posted: Mon Dec 13, 2010 1:54 am
its about 1340 i believe
Post Posted: Mon Dec 13, 2010 6:19 am
So I can put a 3216cc motor in a Zook, I got told GVM x 2.4= most cc motor,
Dose this sound right? So Sr20de is fine,
Post Posted: Mon Dec 13, 2010 6:30 am
I think its still GVM x 1.3 in QLD. :? Thats still 1.74L though
Post Posted: Mon Dec 13, 2010 6:45 am
dose any one know what the exact convertion rate is?
Post Posted: Mon Dec 13, 2010 6:57 am
Page 28 & 31
Post Posted: Mon Dec 13, 2010 8:46 am
is that unmodified? i.e does brakes make any difference?
Post Posted: Mon Dec 13, 2010 8:53 am
Page 31 is schedule 'B', and applies to vehicles with relevent "safety up-grade"
So unless all other 'safety up-grades' have been done in a matter that satisfies the approving officer, your fucked :lol:
Post Posted: Mon Dec 13, 2010 8:56 am
remember a lot of the weight x whatever stuff is for a fully engineered ICV type setup, not stick a big motor in and get a modplate type stuff
so things like suspension upgrades, brake upgrades etc will all come into it
Post Posted: Mon Dec 13, 2010 10:19 pm
my approved dude will be satisfied with brakes :)
Post Posted: Mon Dec 13, 2010 11:30 pm
Can I have his number? So lwb vitara brakes up front and standard fronts up rear would b fine?
Post Posted: Mon Dec 13, 2010 11:44 pm
nah, i have been told that i need the brakes from the same model of car the the motor came from. i.e 2 litre brakes, they are slightly bigger than the lwb 1.6 brakes.
i know it doesnt help you cos its not a suz motor but i would think the biggest brakes you can get would be good enough.
Post Posted: Tue Dec 14, 2010 1:26 am
Do 2L vitara brakes fit?
Post Posted: Tue Dec 14, 2010 2:07 am
If you fit 16" wheels they will fit.
Post Posted: Tue Dec 14, 2010 2:35 am
www.modplate.com.au
Post Posted: Tue Dec 14, 2010 10:17 am
Thanks. So the brakes will bolt on just cut backing plate and 16inch wheels?
Or do I need an adapter plate?
Post Posted: Tue Dec 14, 2010 10:18 am
I'm not to sure about the offset of the rotor. You may need a custom caliper mount.
Tanshi? Any idea on this one?
Users browsing this forum: Google [Bot] and 115 guests
