It is currently Thu Jul 30, 2026 7:57 pm
Post Posted: Fri Dec 17, 2010 4:31 am
Iv bought a falcon 110 amp alternator, started to fit it with no luck.
I have a vitara powersteering setup with wedge adapter kit. And it is hitting on the rag joint, this is when the alternator is as close to the block as possible.
Has anyone done this swap on a Sierra with a g16b and power steering? Did you have the same problem?
Post Posted: Fri Dec 17, 2010 4:52 am
Post Posted: Fri Dec 17, 2010 5:56 am
shit thats a clean alternator!
Post Posted: Fri Dec 17, 2010 6:02 am
It be new :lol:
Post Posted: Fri Dec 17, 2010 6:08 am
yeah I think I could scan the barcode through my monitor.... I have one I picked up for my alt upgrade and it looks NOTHING like that!
Post Posted: Fri Dec 17, 2010 6:09 am
Yep..trying to keep it reliable. But I have to get it on there first. I'm pretty close to cutting a section out of the alternator. I want to drive it this weekend. Iv been thinking one of those rag joint eliminators from low range might work.
Post Posted: Fri Dec 17, 2010 6:55 am
try turning your shaft around?
Post Posted: Fri Dec 17, 2010 6:59 am
I tried, but I just gave it a chinese burn. Am I doing it wrong? :?
Post Posted: Fri Dec 17, 2010 7:07 am
As in.. Put the rag joint near the firewall?
Post Posted: Fri Dec 17, 2010 7:08 am
yeh...... try the other di-erection
Post Posted: Fri Dec 17, 2010 7:10 am
is that a bosch or hitachi alternator? doesnt look like it sits right
Post Posted: Fri Dec 17, 2010 7:20 am
Pretty sure it's a mitsu.. I bought a brand new mitsu plug and it's the right one.
Post Posted: Fri Dec 17, 2010 7:23 am
It isn't bolted in, it's just resting there. It can move nearly an inch closer to the engine.
Post Posted: Fri Dec 17, 2010 9:46 am
why not the other side of the motor where the ac is or are you runing ac
josh AKA Bazook
Post Posted: Fri Dec 17, 2010 10:40 am
Nope no air con.. Ill have to have a look at it tomorrow, the only issue would be the mounting to make the pulleys line up. I have never looked at the a/c mounts....
Post Posted: Sun Dec 19, 2010 9:37 pm
mine sits up tight to the motor using the original 1.3 adjustment arm. etc. on the g16b. Im about to put powersteer in also but it looks like it should all clear.
Post Posted: Sun Dec 19, 2010 11:31 pm
I cut a small piece out of the round protrusion so the alt could sit hard against the water pump. The circled bit in the pic isn't where I cut mine but it is the same on the block side.
Users browsing this forum: Google [Bot] and 263 guests
