It is currently Mon Nov 02, 2026 10:48 pm
Post Posted: Sun Dec 19, 2010 1:30 am
hey guys just wondering if the 1.3 litre axles and diff front and back swap with my 1lt ones
wana do the swap cause my 1lts getting a 1.3 conversion so my as well swap the axles as well anyone dealt with this before and give me some feed back ?
Post Posted: Sun Dec 19, 2010 1:32 am
Are you fitting 1.3 narrow track diff's??? :?
Post Posted: Sun Dec 19, 2010 1:37 am
or wt?
Post Posted: Sun Dec 19, 2010 1:39 am
yeah sorry both are narrow track and i know the hand brake is different.
Post Posted: Sun Dec 19, 2010 1:49 am
You will have to bolt the entire housing's in, may as well do it complete, H/brake's are on the transfer so you won't need to touch anything there..
Post Posted: Sun Dec 19, 2010 1:53 am
yeah i was going to just drop the 1lts complete and bolt the 1.3s complete back up thats why i thought id ask if they would just be a stright swap also are u sure the 1.3 handbrake is on the transfer cause i know my 1lt is but the 1.3 that i have go to direct to the rear drums
Post Posted: Sun Dec 19, 2010 2:21 am
Flange's will be diffrent, you will need the n/t shafts, probly would be best to change over the h/bake's as the stud's out of the drum won't fit the n/t shaft's..
All brake line's should bolt up, it's a reasonably easy conversion..
Post Posted: Sun Dec 19, 2010 2:27 am
are you sure they are nt diffs? i thought it was only WT's that had the handbrake in the rear drums.
Post Posted: Sun Dec 19, 2010 2:28 am
by nt do u mean narrrow track
i think there both narrow track ?
and yeah i was going to swap the hand brake anyway as mine dosnt seem to work that good
Post Posted: Sun Dec 19, 2010 2:30 am
okay now iam confused
how do i check if the 1.3 axles and diff are narrow track or wide track ?
Post Posted: Sun Dec 19, 2010 2:31 am
i still have never heard of a NT with the hand brake in the rear drums. is it a nt that has had wt diffs swapped in?
Post Posted: Sun Dec 19, 2010 2:32 am
run a tape measure along the top of the diff and i will measure mine :lol:
back in a tick :wink:
Post Posted: Sun Dec 19, 2010 2:37 am
okay mines say a 1180mm it was raining and i did it pretty quick haha but its around that and that from say back of drum to back of drum
Post Posted: Sun Dec 19, 2010 2:38 am
from the inside of rear diff flange thing that the brakes bolt to, to the opposite one is 1180mm from memory a NT diff is 90mm shorter.
Post Posted: Sun Dec 19, 2010 2:39 am
well there ya go you have wt diffs
Post Posted: Sun Dec 19, 2010 2:40 am
get a perch kit from fatzook and a wt drag link and it will be a flex machine.
Post Posted: Sun Dec 19, 2010 2:43 am
& some flare's... :lol:
Post Posted: Sun Dec 19, 2010 2:45 am
haha okay this is so wierd i swear it is a nt thoe maybe it has been converted
i brought this whole sierra cut into a custom ute and got told it was a narrow track and i was like cool so gott the whole thing for 350 with a winch and 1.3 and 5 speed like the car was complete just rusted out and painted with a house roller lol so im scraping it but by the looks on the mounts and iam about to go measure them but i think they are wt diffs but already to go into a nt so i hope i scored on that one haha
Post Posted: Sun Dec 19, 2010 2:50 am
go and measure the distance between the rear springs. :D
Post Posted: Sun Dec 19, 2010 2:53 am
i have wt diffs with nt spring spacing. approx 910mm between the springs.outside to outside.
Post Posted: Sun Dec 19, 2010 3:00 am
okay went and had another look and i think it is wide track sierra
how hard is the conversion and is it that hard
Post Posted: Sun Dec 19, 2010 3:06 am
if you can take a photo of the front spring shackle mount we can tell ya for certain what it is.
bogfrog did a great write up on the swap. atari is good at searching :lol:
Users browsing this forum: No registered users and 452 guests
