It is currently Mon Nov 02, 2026 10:01 pm
Vehicle: Jimny
Post Posted: Fri Jan 14, 2011 9:11 am
Probably a silly question but here it goes. When fitting a 2inch suspension lift do you jack up the body then support the diff. Or do you just jack up the diff then take the springs out ?
I have read the tech article but i am still a bit unsure.
Post Posted: Fri Jan 14, 2011 9:15 am
support the diff and the body and only do one side at a time
Vehicle: Daisy
Post Posted: Fri Jan 14, 2011 9:17 am
What keeps the car from falling over? the other three wheels?
Post Posted: Fri Jan 14, 2011 9:22 am
Crack front wheel nuts.
Jack car up from chassis untill tyres leave the ground. (diff should be hanging)
Place jack stands under the chassis.
Release jack.
Remove wheels
Undo U-bolts, shackles and rear spring bolts.
Place jack on one side under the axle and take the weight of the diff. Remove old spring and replace. Put all the bolts etc back in, then remove the jack.
Do the same for the other side.
Tighten all that shit up
Replace wheels
remove from stands,
tighten wheel nuts
repeat at the other end. And chock the wheels before lifting.
Vehicle: Jimny
Post Posted: Fri Jan 14, 2011 9:24 am
As quick as that thanks alot FatZook,
Vehicle: Daisy
Release jack.
Remove wheels
Replace wheels
remove from stands,
tighten wheel nuts
This i what I was thinking!
Post Posted: Fri Jan 14, 2011 9:38 am
Release jack.
Remove wheels
Replace wheels
remove from stands,
tighten wheel nuts
i'm not questioning anything here fatzook, but trying to learn sth new. why removing the wheels is necessary? is it just easier to work or is there any other reason?
i don't remove wheels (have SPOA), but maybe i should :) kris
Vehicle: Daisy
Post Posted: Fri Jan 14, 2011 9:40 am
If you remove the wheels, you could work beside the vehicle way easier couldn't you, rather than having to get under it so far?
makes it easier to work on. (for SPUA)
SPOA.... :roll:
Post Posted: Fri Jan 14, 2011 9:48 am
SPOA.... :roll:
very true, much more room to work when you remove wheels, i don't bother though.
yep SPOA, that's how i bought it, and didn't even know what that meant back than. i lowered my zook as much as i could, but it's to much hassle to swap all back over to SPUA now. i keep my springs as flat as possible.
Vehicle: MY2019 Jimny
Post Posted: Fri Jan 14, 2011 9:20 pm
Also, retighten everything after your first drive, and recheck after a few hundred kms.
Vehicle: '94 suzuki maruti
Post Posted: Fri Jan 14, 2011 10:30 pm
also thats quite a bit less weight you have to piss you off while trying to get the springs back in
Post Posted: Fri Jan 14, 2011 11:56 pm
SPOA.... :roll:
It might make moving/supporting the diff a bit easier by leaving the wheels on, but it limits access to the u bolts, etc. Not a problem for a skinny bugger like you, but for other guys it makes it way easier.
Users browsing this forum: No registered users and 108 guests
