It is currently Fri Jul 31, 2026 2:55 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
Post Posted: Sun Jan 16, 2011 7:40 am
Ok well doing the baleno conversion, all finished just cant get it to start, there is.
spark
injector pulse
fuel pump primes and runs when turning over.
I gone through all the wiring and all seems good.
When i take the plugs out and turn it over i cant smell fuel or anything in the cylinders.
I am using a vl fuel pump, i changed it for a new one for a test no differance.
The guy i got it from got the ecu from an automatic if thats a problem.
Here is a picture of the sticker on the ecu
If that helps.
any help would be great!!
My Maruti build, Click WWW
Post Posted: Sun Jan 16, 2011 8:02 am
Being from an auto is not the problem. Both mine and matts (work horse build) are from autos and run fine.
Your problem lies elsewhere. :cry:
Auto shouldnt be a problem.
Hows the cam/crank sensor
Post Posted: Sun Jan 16, 2011 8:06 am
brand new cam sensor that when i put a test light on it and crank it it pulses, the crank sensor when i have it on ignition and take it out near any metal it makes the fuel pump prime so im guessing it works.
Also i replaced the timing belt, took that all appart today to check it and the marks are still lineing up, and the crank sensor looks fine on the bottom cog.
Post Posted: Sun Jan 16, 2011 8:09 am
Dizzy timing out by 180 degrees??
Post Posted: Sun Jan 16, 2011 8:16 am
Nope, no dizzy... this one's got me a lil stumped..
http://www.ptjau.com/images/sierra/bale ... ringv1.pdf
here the wiring diag he used..
Try that one.. :roll:
Post Posted: Sun Jan 16, 2011 8:24 am
^^ No worky :roll: Stupid question time.....no dizzy ????
Post Posted: Sun Jan 16, 2011 8:28 am
Coil pack motor
Post Posted: Sun Jan 16, 2011 8:29 am
Fixed that..
yer, no dizzy, it run's by getting signal's from the crank & cam sensor's to run the coils & injector's....
Post Posted: Sun Jan 16, 2011 8:30 am
steak_knife wrote:
Fixed that..
Learn something new every day then hey :P Turn the coils around then :roll: :lol:
Post Posted: Sun Jan 16, 2011 8:33 am
With the wiring diagram it shows a pin for sensor earth that runs to some of the sensors is this ment to be earthed aswell or does the ecu do that ?
Post Posted: Sun Jan 16, 2011 8:34 am
There is no harm in earthing it, but buy the look's of the diag it earth's through the ecu..
Post Posted: Sun Jan 16, 2011 8:38 am
do you have fuel pressure at the rail??
Post Posted: Sun Jan 16, 2011 8:39 am
Fuel line blockage?
SS
Post Posted: Sun Jan 16, 2011 8:43 am
he blocked the return to make sure the reg wasn't bleeding off...
Post Posted: Sun Jan 16, 2011 8:47 am
fuel pressure?
lol opps too late
Post Posted: Sun Jan 16, 2011 8:52 am
when was the motor last run??
Post Posted: Sun Jan 16, 2011 9:02 am
I'll let him tell you where he got it from... 8O
Post Posted: Sun Jan 16, 2011 9:04 am
This sounds interesting :)
Post Posted: Sun Jan 16, 2011 9:08 am
8O
Anyway, he has checked the main earth's, th cam sen signal & power, fuel pressure ( with out a gauge), it has spark & the inj's have pulse.. :? friggin thing.. :roll:
Post Posted: Sun Jan 16, 2011 9:14 am
steak_knife wrote:
8O
If it has spark, fuel, and injector pulses then it must be timing related.
Lil Foot!
Post Posted: Sun Jan 16, 2011 9:15 am
I have had engines that have sat for a while ... where the injectors have "siezed" shut.. tapped on them a few times and they started to work.
oh...
and who did he get the engine from?
Post Posted: Sun Jan 16, 2011 9:17 am
Agreed, but he stripped the cover off today & double checked, a mate of his is a mechanic & fitted the new belt..
But don't they have 2 tdc's on the cam? :?
Post Posted: Sun Jan 16, 2011 9:26 am
JrZook wrote:
if it has spark, fuel, and injector pulses then it must be timing related.
I would agree... but he isnt getting any fuel by the sound of it .. no fuel smell when plugs are removed ..
Post Posted: Sun Jan 16, 2011 9:29 am
Lol motor is from vw Dave,
Deffently fuel pressure at the rail.
The motor has been sitting about 6 months maybe longer.
Post Posted: Sun Jan 16, 2011 9:31 am
Yeah the timing belt was just a replace so lined up both marks pulled belt, new idler and new belt, checked marks, still line up and it's turned over heaps
Post Posted: Sun Jan 16, 2011 9:39 am
oh...
Sounds like this could be a win, I pulled off the fuel rail this arvo, what do you 'tap' them with an
Post Posted: Sun Jan 16, 2011 9:48 am
I just use a screw driver handle and tap the injector..
my guess, crack the big nut/bolt on the end of the fuel rail when the pump is priming and there should be heaps of pressure in the rail and very slowly undo it until fuel sprays out, seriously it should be so much pressure it will cover your whole car if you undo it any further. if thats it check your fuel pump isnt getting hot as you might have it wired the wrong way alot of those style pumps have no + or - marks.
Otherwise check all earths particulary the injector earths, also check the injector is pulsing by using a small simple globe plugged into the injector plug pins.
Post Posted: Sun Jan 16, 2011 6:30 pm
Fuel pressure on the wrong end of the rail. So even crimping the return your only blocking the the input.
Otherwise spend the extra and get the injectors flowed. Won't hurt anyway
Users browsing this forum: Google [Bot] and 409 guests
