It is currently Tue Nov 03, 2026 9:55 am
Post Posted: Mon Jan 17, 2011 1:11 am
Searched with no luck.
Can anyone tell me how to remove the window winder from the inside of the door on the sierra.
Thanks
Post Posted: Mon Jan 17, 2011 1:49 am
It has a funny clip thing behind the plastic sleeve.
It locks into 2 grooves across the spline.
It should pull out fairly easy,
but it can disappear into the blue yonder and never be seen again :)
Post Posted: Mon Jan 17, 2011 2:01 am
use pliers or something to get the circlip off and it will just pull of then
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Mon Jan 17, 2011 2:04 am
use the seat belt or a the edge of a tee shirt & slide the edge around between the door trim & the winder, yes it will fly across the shed.
Post Posted: Mon Jan 17, 2011 2:08 am
i couldn't see a circlip. will have another look in a sec as the car is at work.
Post Posted: Mon Jan 17, 2011 2:18 am
it appears there is no circlip there or even anywhere that on would sit. The handle just came straight off the spline with some gentle persuading.
Thanks for the help anyway.
Post Posted: Mon Jan 17, 2011 8:12 am
hence known as a jesus clip..
"jesus where the hell did that go?"
Post Posted: Tue Jan 18, 2011 2:55 pm
a use an old T shirt or similar the clip should stay with the rag when removed you might need a small screw driver to get the rag under the plastic doever the pointer bits of the clip normally face towards the handle
Users browsing this forum: No registered users and 78 guests
