It is currently Tue Nov 03, 2026 7:53 am
Vehicle: SJ80
Post Posted: Tue Jan 18, 2011 9:12 am
Have a coily - and am very slowly heading down the planning stages of fitting an injected engine in place of the ol carby 1.3.
Started to have a poke around under the dash to find a mounting spot for the ECU.
Where do people tend to mount them?
Looks like there is a little, emphasis little, bit of room under the dash on the far passenger side, but getting in there to drill some holes is going to be a right pain.
What are the other options for a mounting spot?
What have other people done?
Post Posted: Tue Jan 18, 2011 9:18 am
A lot have put it in behind the instrument cluster..
Just about any place dry will do, but that do put out a bit of heat, so best not rest it against a harness...
Post Posted: Tue Jan 18, 2011 9:28 am
behind dash pasingers side up top. mount fuel pump and ecu relay on same bolt. i can try 2 get a pic of mine.
Vehicle: I drive your mum
Post Posted: Tue Jan 18, 2011 9:30 am
Mine is up behind the glove box, with my relays just next to it and the PC cord looped over a velcro tab nearby. Its no fully waterproof there if i flood the cab, but i only drive rocks so its pretty safe.
Layto....
Post Posted: Tue Jan 18, 2011 9:57 am
Layto....
X2.
And I mounted matts ECU and TCM up there on the workhorse also. There may be a partial pic in his build thread. :?
Post Posted: Tue Jan 18, 2011 11:09 am
Layto....
x3.
I wrapped mine in a glad bag.Keeps dust out. And whatever water i hose it with. :lol:
Vehicle: Zookless
Post Posted: Tue Jan 18, 2011 11:46 am
Here's where mine is -
Post Posted: Tue Jan 18, 2011 12:34 pm
mines tucked up under/behind the glove box with a little fabricated box and bracket thing holding it there.
Post Posted: Tue Jan 18, 2011 9:30 pm
I think behind the glovebox is the best place. There is a bracket that the standard emissions control box mounts to, you could use that. I would probably brace it a bit better though as the ECU is a bit bigger and heavier. Also keep in mind that the bonnet release cable is back in there too.
Due to the length of the wiring loom I had to mount mine on the driver's side. It is a PITA to get in back there (as you can see by CairnsZook's pic it can get a bit crowded). I pulled the dash out and made up a bracket to fit mine.
Post Posted: Wed Jan 19, 2011 4:19 am
vitaras have it mounted behind the drivers side speaker in the dash. below the steering wheel level
Post Posted: Wed Jan 19, 2011 5:07 am
The GV model is under the glove box on the passenger side. It is prone to water overflow from A/C if for some reason water cannot escape, but other than this is high and dry.
After my subsequent mishap with A/C water mine is wrapped in a plastic bag. Quite OK to cover in plastic bag according to my mechanic.
Online
Post Posted: Wed Jan 19, 2011 7:03 am
It's easiest to mount behind the glovebox. That's where they are mounted on EFI sierras.
It's where I've put them on the EFI conversions I've done.
Vehicle: SJ80
Post Posted: Wed Jan 19, 2011 7:21 am
I also mounted mine up behind the glove box. Below is a photo of it with the dash removed. I also have a coily, I'm not sure about other models, but there are two captured nuts there to mount the ECU bracket on. So I didn't need even need to drill holes.
It seems they're there to mount an ECU in that position, as Gwagensteve said.
Vehicle: SJ80
Post Posted: Wed Jan 19, 2011 11:41 am
[quote="bagnkat"]Below is a photo of it with the dash removed. I also have a coily, I'm not sure about other models, but there are two captured nuts there to mount the ECU bracket on. So I didn't need even need to drill holes.[quote]
So can you get it in and out without removing the dash? or is removing the dash required?
I will have to go and have another look with more light.
Thank you for all the answers and responses everyone.
Sounds like the 2 best options are behind the glovebox, or behind the instrument panel.
Users browsing this forum: No registered users and 93 guests
