It is currently Mon Oct 19, 2026 4:35 pm
Post Posted: Fri May 23, 2008 10:00 pm
i brought a piranha kit and the guy told me just to pop the factory cap off and the new air line will go straight on but thats not the case i pop it off and there's a hole nothin to put the line on to whats next help cheers nick
89 WT H/top 1.6 8v SPOA 2" B/L virtara power steer
Vehicle: 75 Cruiser
Post Posted: Fri May 23, 2008 10:08 pm
doesn't the hose fit over the diff breather nozel thingy?
did you tell him it was a sierra? I guess ya did?
Post Posted: Fri May 23, 2008 10:52 pm
the hose supplied should fit straight over that and then clamp it up.
But what I done on mine was get a 1/8bsp tap, ran it down that hole (perfect fit, no drilling required) and then screwed a brass hosetail fitting into it and used a smaller hose. (half inch hose is major overkill)
just make sure to change the diff oil after doing this and give it a blow through to remove any filings.
Post Posted: Fri May 23, 2008 11:49 pm
i used about 100mm of 1/2 fuel line
1/2 male barb 1/4 bsp to 1/4 female barb 1/4 bsb. (2x front/back)
4m 1/4" fuel line.
8x Clamps to suit.
2x inline fuel filters. rpf1005
cost under $40
Post Posted: Mon Jun 16, 2008 9:06 pm
once you undo the factory diff breather i assume that it will unscrew from that welded nutsert??? what size is the hole/thread so that i can put some festo quick fit elbows in help asap cheers at work for anoth 1hour need to know so i can buy some from work.cheers nick
Post Posted: Mon Jun 16, 2008 9:10 pm
The cap is just crimped on, you can pry it off with a screwdriver. Underneath that cap should be a spring which holds a little disk down over the nipple welded into the diff housing.
Post Posted: Mon Jun 16, 2008 9:15 pm
so that factory fitting shown in the picturte does not un screw???
Post Posted: Mon Jun 16, 2008 9:37 pm
No, it's welded into the housing.
Post Posted: Mon Jun 16, 2008 9:48 pm
damm ok no probs thanks for your help.
Users browsing this forum: Google Adsense [Bot] and 355 guests
