It is currently Mon Oct 19, 2026 11:40 pm
lesspostingmorewheeling
Post Posted: Fri Jun 20, 2008 2:18 am
does anyone make vinyl floor covering(carpet) for sierras like the factory stuff that comes one soft top? i've seen carpet for them on ebay but not the vinyl
Mike
Post Posted: Fri Jun 20, 2008 2:21 am
aftermarket vinyl....tried but i don't think so....
Post Posted: Fri Jun 20, 2008 2:23 am
most of the mobs that do molded carpets also do vinyl, jsut whether or not they do it for sierras is another matter
Post Posted: Fri Jun 20, 2008 2:38 am
i like the clips and the factory fit so does anyone have the original vinyl (in pretty good nick) that they aren't using? :twisted:
Post Posted: Fri Jun 20, 2008 6:09 pm
If you were in Brissie I'd offer to swap. Mine is good but a little muddy still.
Post Posted: Fri Jun 20, 2008 7:08 pm
go talk to a shop like clark rubber or some where like that, get some of the vinyl (not the thin stuff you use for seats, door tims) a heat gun,stanley knife and away you go. once you heat it up and let it cool it will hold the shape pretty well or you can glue it down in a few spots if you don't want it to move. shouldn't be more that $100 to do the whole car.
Post Posted: Sat Jun 21, 2008 12:15 am
Have you done this before? if so any chance of some pics?
Post Posted: Sat Jun 21, 2008 1:15 am
Hang on, Sierras came with floor coverings?!
92 WT softback ute, twin lockrights, 3.9 diffs, S1
Post Posted: Sat Jun 21, 2008 1:17 am
well in tassie they did :P
Vehicle: 75 Cruiser
Post Posted: Sat Jun 21, 2008 1:23 am
floor coverings just hide the dirt and rust!
the only floor covering should be the bung hole plug :)
Post Posted: Sat Jun 21, 2008 1:29 am
its good for covering up dents too :wink:
Post Posted: Sat Jun 21, 2008 2:29 am
i haven't done it in a sierra but i'm a vinyl layer by trade so i know what i'm talking about.
have to say i agree with steve, it will just hide dirt and water witch will rust.
Post Posted: Sat Jun 21, 2008 2:36 am
ok then i'll have to give it a try my floor looks shit without the floor covering its all dented and has this crappy sound deadening stuff thats all chipped and cracked and i'm not planning on getting my floor panel beated :lol:
Post Posted: Sat Jun 21, 2008 2:46 am
if you glue the whole thing down it wouldn't get to much stuff under it but the floor needs to be pretty sound, no dints as vinyl shows up and mark and will make it look worse and water eats away all glue that works with vinyl.
why not go carpet, just go to a carpet shop an grab some half desent carpet out of there hopper and stuck it down, will hide the dints, warm, sound proof it abit and cost you nothing. you just need a knife and some glue
Post Posted: Sat Jun 21, 2008 2:57 am
i think i want to have it removable because when i bought the car i lifted up the vinyl and there was like 10mm of mud covering the whole floor so i want to be able to hose it out so i don't get any rusty surprises in the future
Post Posted: Sat Jun 21, 2008 3:05 am
with the carpet i'd just put a little bit to hold it up the fire wall and any where else it folds over itself. the rest will sit with the weight of it and just rip it out when wet and dry or chuck it out.
Post Posted: Sat Jun 21, 2008 3:12 am
could i use that chequer plate vinyl stuff or would that be too thick to shape around the wheel arches and trans tunnel?
Post Posted: Sat Jun 21, 2008 3:17 am
no just heat it up from the back and make sure the front plastic doesn't peel from getting to hot. if its thick wear gloves as you'l have to hold it in place to "set" and it will need to be heated up abit more.
Post Posted: Sat Jun 21, 2008 3:21 am
ok i'll have to look around and see what i ca get my hands on thanks for the info
Users browsing this forum: No registered users and 239 guests
