It is currently Fri Jul 31, 2026 4:32 am
Post Posted: Sun Jan 30, 2011 9:10 am
Hey guys, I have a 1991 vitara 1.6 EFI engine, which I thought they were G16B ? And I thought the G16A were the carby models?
Anyways, when I pulled the 1.6 out of the vit yesty to get ready for the rebuild, I noticed it had G16A on the block?
Im really confused now, I done a quick search on google and google images bu didnt really get cleared up on.
Thanks...
Post Posted: Sun Jan 30, 2011 9:12 am
Imported eng's are A's from what I've been told...still 16v efi, but stamped A....
Post Posted: Sun Jan 30, 2011 9:13 am
So when I order my engine rebuild kit, would I tell them its G16A
Post Posted: Sun Jan 30, 2011 9:14 am
Also, cheers for the quick reply :D
Post Posted: Sun Jan 30, 2011 9:18 am
i think the g16b and g16a blocks are the same its just the heads are different
u can get g16a carby and efi, and the g16b is only efi in aus i think
some one can correct me if im wrong
Post Posted: Sun Jan 30, 2011 9:19 am
A was first, B was second, easy ey :)
just ask for parts for a G16A 16 valve EFI
Post Posted: Sun Jan 30, 2011 9:20 am
No, cause you'll get 8v stuff, this is one reason I prefer eng's that were in an Aus released car, some lil thing's could/will be different.
At a guess the gasket's should be the same as the 16v B eng's here.
Post Posted: Sun Jan 30, 2011 9:21 am
i would tell them g16b efi kit so you deffently get the 16 valve piston
Vehicle: 4wd
To add confusion what model where the 8v motors and did we get them here in aus?
Watch out or you'll get sued.
Post Posted: Sun Jan 30, 2011 9:25 am
yes 88 to 93 model
Post Posted: Sun Jan 30, 2011 9:26 am
A is Denso??? :?
Vehicle: 2018 DMAX
Post Posted: Sun Jan 30, 2011 9:29 am
A is Denso??? :?
At first i though mine was an A been denso.. but you told me otherwise dude :shocked:
All the parts i have ever orderd have been G16B stock and worked
Post Posted: Sun Jan 30, 2011 9:31 am
zooky08 wrote:
yes 88 to 93 model
SWB
Post Posted: Sun Jan 30, 2011 9:32 am
defiantly ask for the g16b stuff other wise you will get the wrong gear i have the exact same problem with mine i asked for the g16a and got the wrong gear. the only thing i had trouble with was the dizzy and the rotor button.
Post Posted: Sun Jan 30, 2011 9:33 am
A is Denso??? :?
Think its more like G13A and BA, there were internal changes, different crank sounds familiar?
remember these engines were legit in swift sedans and even carby so they have been around a bit
Post Posted: Sun Jan 30, 2011 9:38 am
:roll: I don't even listen to me... :roll:
Royce, I have noticed the import/swift eng's have a brace over the main cap's to..
Post Posted: Sun Jan 30, 2011 9:40 am
Cheers guys, Yeah I will definanly be making sure I get the right parts!
Thanks everyone.
Post Posted: Mon Jan 31, 2011 8:49 am
im Pretty sure the 16V G16A has a Weaker Crank Vs a G16B apart from that from what i was aware they are identical
Stocker
Post Posted: Mon Jan 31, 2011 8:59 am
Well from my observations the only difference between the later model G16A MPFI motor and the domestic G16B is 1 letter in the engine number designation. :?
Users browsing this forum: Google [Bot] and 554 guests
