It is currently Fri Jul 31, 2026 2:01 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Tue Feb 01, 2011 4:12 am
I can get some 1982 hilux diffs and gear box and transfer case will any fit onto the 1984 lwb suzuki that I want to do up ?.
Post Posted: Tue Feb 01, 2011 11:39 am
Anyone ?.
Post Posted: Tue Feb 01, 2011 11:57 am
reece wrote:
Anyone ?.
1/2 down the first page is a good write up. http://www.auszookers.com/index.php?name=News
you'll want/need a Bundera rear diff though.
Post Posted: Tue Feb 01, 2011 12:02 pm
So no chance of fitting diffs ?.
What about gear box and anything else.
Post Posted: Tue Feb 01, 2011 12:15 pm
hilux diff install was in that link i posted. not sure about gearbox.
EDIT: why not use what you can out of this in the LWB & add the Hilux diffs if required. http://auszookers.com/index.php?name=Fo ... ic&t=18070
Post Posted: Fri Feb 11, 2011 9:24 am
Just bought a suzi ute with mods.
Post Posted: Fri Feb 11, 2011 9:31 am
I've seen that purple/pink overspray before... :?
Post Posted: Fri Feb 11, 2011 9:40 am
WOW!! Thats fantastic!
Post Posted: Fri Feb 11, 2011 9:41 am
which bit? :?
Vehicle: I drive your mum
Post Posted: Fri Feb 11, 2011 9:42 am
8O 8O
Layto....
Post Posted: Fri Feb 11, 2011 9:43 am
which bit? :?
The white bit in between the worst 4 link rear I have ever seen and the best front guard chop I have ever seen :roll:
Post Posted: Fri Feb 11, 2011 9:49 am
which bit? :?
Bwahahahahaha. The upper diff end mounts make baby Jesus cry, and punch kittens at the same time.
Layto....
Post Posted: Fri Feb 11, 2011 9:51 am
pretty sure that chassis was for sale on here a while ago...
No postive feedback
Oh well sh&t happens.
It has been modded for a ca18 motor and was registered.
Post Posted: Fri Feb 11, 2011 9:54 am
which bit? :?
Layto....
Seriously though, Its way tall, the rear diff is so far back its pointless, the links are insanely long....could be 300-400mm shorter!!, The weight balance would be fucked with the diff where it is, the lower links strike the rail at rest 8O , the upper link mounts are an abortion, the lower coil retainers are an 8 or 10mm bolt that will stop the coil from coming directly out, but if the coil turns for some reason, they will do nothing at all, and i can't tell from the pic, but it looks like the shocks will strike the upper link mounts under compression.
Thats just the rear end.
All I can say is, I hope the cab was worth what you paid for it, and I hope you have plans to reign that rear end in. :wink:
PS. What are YOUR plans for it?
pitty sooky zookster666 deleted his pics... but it smells just like this one.
http://auszookers.com/index.php?name=Fo ... ght=rotary
http://auszookers.com/index.php?name=Fo ... pic&t=8328
Post Posted: Fri Feb 11, 2011 9:57 am
Its not that one. It was a SWB chassis, and had a chopped SWB tub.
Post Posted: Fri Feb 11, 2011 10:05 am
not thats seriously fucked up :lol: :lol: :lol: :lol:
Post Posted: Fri Feb 11, 2011 10:20 am
Only paid $300 for it so since the rear end is no good how about someone help with what it should look like.
Post Posted: Fri Feb 11, 2011 10:30 am
Mate for $300 its a great starting point.
IMO you need to move that rear diff forward atlest 10". you would benifit from moving the front diff forward 2-4" depending if you want to chop the front guards or not.
Before we start getting into the how you should and shouldn't build stuff dribble, why don't you sit down and have a good think about where you want this project to go. What mods do you want etc. Then worry about their execution.
Post Posted: Fri Feb 11, 2011 10:34 am
I just want make a good fun car to match it with the cruisers and patrols.
Post Posted: Fri Feb 11, 2011 10:42 am
Thats very vague. And you will continue to recieve useless 'advise' until you come up with a game plan.
Be particular. Do some research on other zooks you like. Get some ideas, then ask some real questions. I'm not trying to be a wanker, but you can't just buy a zook and then get everyone else to design if for you. This is something that YOU need to do.
Post Posted: Fri Feb 11, 2011 10:43 am
a stocker on 30's will do that :lol:
Post Posted: Fri Feb 11, 2011 6:44 pm
If you have never built up a zook before i would suggest looking around and basing your buildup on proven rigs that perform well.
Start with the tyre size and wheelbase you want to acheive and go from there.
Coiled or leaf?
Ive only seen a small handful of successful coiled zooks. Most other should have kept their leaf springs.
There are a few buildups and photos that will get you going on here. Look at bluesuzy or mine for a start.
Post Posted: Sat Feb 12, 2011 12:48 am
Hey mate this is what I'm building now a hard top sierra i have done the 1.6 efi vitara conversion hilux diffs and i have done a 3 link front with coilovers and when money allows ill 4 link the rear and run coilvers too.
I also had a 1986 with wide track Sierra diffs locker in the front with 6.5 crawler gears on 31s with RUF an followed my mate with 35s on there cruisers an pooptrols have a look around in the garage of a few different rigs and go from there
Brodie
100 series cruiser 4 inch lift and 35s
1990 sierr
Post Posted: Sat Feb 12, 2011 1:06 am
Thanks for reply brodizook but can't open photobucket link and I was thinking of taken what I need of lwb and getting rid of it as it needs more work than the ute.
Post Posted: Sat Feb 12, 2011 1:12 am
sorry mate should be fixed now um it really depends of how far you wanna go with it .
my old sierra on 31's when everywhere one thing i would have done differently would have been going chromo axles in the front so i didnt smash cv's apart
brodie
1990 sierr
Post Posted: Sat Feb 12, 2011 1:16 am
If I had both of then I would be keeping the Lwb chassis & using the ute tub, providing the lwb isn't rusted.
At least that way the lwb hasn't been frucked with, you don't have to chop all the shit out of it..
That's my opinion..
Post Posted: Sat Feb 12, 2011 2:57 am
So you guys are telling me that the rear end of ute is Fu$ked and no way of changing it.
Is there much to change ute cab to long base and should I keep leafs or go to coils ?.
Post Posted: Sat Feb 12, 2011 3:11 am
Can you get some more pics of the rear end ? I cant see it being to much of a problem changing it but I think if you fix the rear coil suspension and run some rear springs in the front mould work pretty well what size tyres do you wanna run?
Brodie
1990 sierr
Users browsing this forum: Google [Bot] and 331 guests
