It is currently Mon Oct 19, 2026 3:03 am
Vehicle: 30s front locker barwork
Post Posted: Mon Jul 07, 2008 10:39 pm
hey everyone
just got a question as much as i would lik 31s i dont really hav the money for a body lift n plus i am lookin to buy another car i hav a 2 inch spring lift in now n i amwonderin wat would be the bigest size u think i can run with that i would lik it as close to bein legal as possible
n also if any on has a spare stock rim siten pm i need one
any help would be great thanks guys
Vehicle: 75 Cruiser
Post Posted: Mon Jul 07, 2008 10:47 pm
If you just have a 2inch spring lift i'd suggest getting 235s. I have the same setup on my white sierra, I used to have 30s which was ok for most stuff but under full flex it scraped the front tyres a bit. Depends what kind of tracks and driving you like to do i guess.
Post Posted: Mon Jul 07, 2008 10:50 pm
legal is 15mm above standard too, which limits you to 215/75
there are no shades of legal either, IE 235 arent more legal than 37's
but 235 is a good fit and pretty popular
Post Posted: Mon Jul 07, 2008 10:56 pm
my insurence goes out the window if i hav bigger tires above legal like thirdparty n that doesnt it
Post Posted: Mon Jul 07, 2008 10:59 pm
I know plenty of people that havent had any trouble
they need to prove the tyres cause the accident, so if you ran into somebody they could say that was the fault
Post Posted: Mon Jul 07, 2008 11:14 pm
okay thanks i mit look in to that size tires
i think ferdral make a mud in that size
only have 2inch spring lift on my car and veryhappy with 235-75-r15 silverstones at117 special $150 per corner good on road not bad off no rubbing :)
Post Posted: Tue Jul 08, 2008 12:42 pm
in vic for a live axle vehicle its 50mm above the largest tyre that was available for that diff. note i said that diff and not that vehicle. 31's are the max legal tyre i can engineer. on ifs cars its usually 15mm above standard as thes generaly have a different wheel bearing arrangement.
Post Posted: Tue Jul 08, 2008 10:54 pm
lucky bastard that is the shit thing with livin in qld is the rules
Post Posted: Wed Jul 09, 2008 11:12 pm
so i queensland there is no way to make like 30s or 29s legal is there
Post Posted: Wed Jul 09, 2008 11:14 pm
yes, remove your compliance plates, build it with components designed to handle those loads and get an engineer to sign off on it and register it as a ICV
Post Posted: Wed Jul 09, 2008 11:17 pm
is that hard to do n wat would i need for it
Post Posted: Wed Jul 09, 2008 11:18 pm
Post Posted: Wed Jul 09, 2008 11:26 pm
you will be registering it as a seen 4x4 mk1
count on a a few thousand in engineers fees alone
Post Posted: Wed Jul 09, 2008 11:37 pm
crap that is a lot y so much dont they jst hav to look it over n with i icv could i hav excend shackles
Post Posted: Wed Jul 09, 2008 11:41 pm
no an engineer has to do a full report on why the car is safe and meets ALL ADR's aplicible to it
Post Posted: Sun Jul 13, 2008 10:08 pm
so the largest legal tire i can go is 215 75R 15
so if i fit 235 it is illegal but they hav to prove that it was the tires that cause the crash am i correct
Post Posted: Sun Jul 13, 2008 10:09 pm
Post Posted: Mon Jul 14, 2008 4:05 am
yes and also depending on how large you go before the engineer will pass you he will make you upgrade components like your brakes and the necesities so they can deal with the out of wack gearing
Post Posted: Tue Jul 15, 2008 2:01 am
In VIC it's +50mm for 4wd's, solid of IFS.
Users browsing this forum: No registered users and 291 guests
