It is currently Wed Nov 04, 2026 4:58 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Mon Feb 21, 2011 12:34 pm
Has anyone done it from on here?
I have seen build thread a while ago from someone in the states who as completed it in his lhd samurai.
I am just tossing up my options for my lwb sierra.
Its is going to be alittle on the heavy side as it is, winch, lux/bundy diffs, armour, tube work, bigger tank etcetc.
I have a G16b Baleno motor here, but i think the poor little motor may not be up to the task, in power, and fuel economy as it will be under load constantly from the weight..
Body/tunnel work is no prob, Half the floor is going to be cut out anyway..
I need opinions on gearing also. Auto/Manual, and what Gbox to run, will sierra transfer hold or run vit trans with shit chain etc, And if the rear diff has to swap central to lux, so be it..
Post Posted: Mon Feb 21, 2011 12:49 pm
2.0 V6 into Sierra
Post Posted: Mon Feb 21, 2011 12:54 pm
303zuke wrote:
That never eventuated. Motor went into the rally X-90 instead.
Personally I think if you are considering the 2.0 V6, you should seriously consider the J20. Its only a couple KWs less, but fits nicer, and only attracts 4cy rego. 8)
Post Posted: Mon Feb 21, 2011 12:55 pm
Wow! thanks, I will have to have a good read erm..later today. Dont mind the toyo transfer idea either. Plenty of gearing options. And no shit chains.
Vehicle: Vitara 1995
Post Posted: Mon Feb 21, 2011 10:04 pm
doesn't the J20A use chain belt? Can this be changed, is there any reason that should be changed to a belt during the conversion? thought I'd ask, cuz I have no clue.
Post Posted: Mon Feb 21, 2011 10:18 pm
yes the j20 transfer does use a chain in the transfer, however when putting it into a sierra i removed the transfer any way so no issues there.
Post Posted: Mon Feb 21, 2011 10:27 pm
So over a good read, I basically want a Lux gearbox and geared transfer. Vit v6 box input shaft, and Vit v6 bellhousing. To run a H20-H25-H27
Then reduction gears will be needed anyway.
Who would sell me a vit v6 input shaft and a bell housing, clutch plate etc :lol:
Post Posted: Mon Feb 21, 2011 10:36 pm
you would probably find it would be cheaper and easier to pick up a front cut, with engine and gearbox inclusive.
for around 2Kish
Post Posted: Mon Feb 21, 2011 10:41 pm
Yeah would probably need anyway it for all wiring etc. Will be hard to find part here part there etc. Rather all matching from the same car.
Post Posted: Mon Feb 21, 2011 10:44 pm
A guy in the nsw Suzuki club had a 2.7 in his lwb .
It was crazy fast. But it used to twist the chassis when u stomped on it at lights.
It was sold last year.
If u went 4 speed auto u could go undertaker to vit tc with 4.2 gear then 4.88 diffs would be good for 35+ and would have center output so u could use hilux rear instead of crap bundy that like to twist splined off all the time
a while back i had an h20 to put in the sierra, we measured it up and it with some removal of crossmembers it looked like it would fit nicely.
At the time i couldnt find an engineer who would sign off on it. If i had the engineer then that i have now, i would have had an h20 in the sierra for about 5 years lol.
Post Posted: Mon Feb 21, 2011 11:07 pm
Yeah to me a H20 is not worth the trouble. Rather run a H25 or H27 with same fuel economy. H20 getting old also.
Post Posted: Mon Feb 21, 2011 11:16 pm
None of this bothers me. My snake in the bonnet is the fact that the H20 is the same amount of work to fit, but you get far less for all your efforts. :roll:
Post Posted: Mon Feb 21, 2011 11:28 pm
yeah my point was that an h20 and an h27 would be pretty much the same work to fit. if an h20 fits then so will the others
Post Posted: Mon Feb 21, 2011 11:36 pm
Yep. :D
Post Posted: Tue Feb 22, 2011 3:58 am
Undertakers are not in production at the moment and won't be till May at the earliest....
Post Posted: Tue Feb 22, 2011 4:39 am
I wouldn't go a h20 they have shit all torque down low
Post Posted: Tue Feb 22, 2011 4:55 am
Have you driven one in a sierra before?
Lil Foot!
Post Posted: Tue Feb 22, 2011 5:23 am
Doesn't matter Dan. If you can fit a H20, then you can fit a H25 :twisted:
Post Posted: Tue Feb 22, 2011 5:56 am
But you might only be able to Register and Insure a 2.0 in a 1.3 car, but not a 2.5 or 2.7
Post Posted: Tue Feb 22, 2011 6:12 am
I've got approval for a 2L in a 1L car. I reckon I could get a 2.5L passed :wink:
Post Posted: Tue Feb 22, 2011 6:21 am
What you putting in your ute anyway? Hope it aint something run of the mill :P
Lil Foot!
Post Posted: Tue Feb 22, 2011 6:25 am
Its got a G16B in it. :roll:
Post Posted: Tue Feb 22, 2011 6:27 am
we had a yes to a j24 in an lj81 but couldnt source a motor :(
Post Posted: Tue Feb 22, 2011 6:33 am
HELL YES!!!! I'd buy a new GV, just to strip it for the motor!! :twisted:
Post Posted: Tue Feb 22, 2011 6:35 am
Well there you go, new non-run of teh mill engine for your ute. Time to get cracking!!
Anyways what are the weights of these v6's?
Lil Foot!
Post Posted: Tue Feb 22, 2011 6:39 am
Maybe for the next rebuild :roll:
tombutt has a dead H20 he may be able to weigh.
I'll have the J20 out of the wreck in a week or two.
Post Posted: Tue Feb 22, 2011 6:46 am
there is a few 2.4 vits on tradpost atm. Being wrecked.
Would the j24 be worth it? Chuck the transfer in the bin..
Post Posted: Tue Feb 22, 2011 6:47 am
Post Posted: Tue Feb 22, 2011 6:48 am
Its a BRILLIANT motor!! 130kw -ish, smooth as silk, great economy and torque. 8)
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 74 guests
