It is currently Thu Nov 05, 2026 1:02 am
Post Posted: Fri Mar 04, 2011 11:01 am
Picked up my 04 carry today and after sitting for 4 years it would seem the fuel filter is blocked to the shithouse, symptoms are engine cuts out normally after cornering hard or going over bumps the proceeds to run shit until i turn it of for a bit. If i put my foot flat it's like turning on and off a light switch power on then off then on then off, you get the idea. After an extensive search i couldnt find the filter so i thought it might have an intank one, tried to remove the pump assembly but the tank needs to be dropped as its huge.
the car starts and idles fine it is just under load.
should i clean out the tank or take it to get the filter/pump checked and cleaned or can i do it myself.
Hi hun this is my new work car i spent $$$ to get, good isnt it. But i cant take you for a drive cause its rooted and i have to fix it.
went down well let me tell you
Post Posted: Fri Mar 04, 2011 11:12 am
In tank from memory, first ting I would look at would be fuel pressure & condition..
The 13bb's like to shit TPS's, give's an awesome flat spot, but not normally form idle to WOT..
Would be worth changing spark plug's to.
Post Posted: Fri Mar 04, 2011 11:22 am
Are you running 4yr old fuel? Or did you dump it and put some fresh stuff in?
can i just clean the in tank filter/mesh or do i have to replace it.
i think there might be a heap of shit in the tank after sitting for so long,
cornering and going over bumps are really the only things that set it off.
fuel was less than 1/4 and i just filled it up with 98
Post Posted: Fri Mar 04, 2011 11:29 am
that'll do it.....
ah crap
Post Posted: Fri Mar 04, 2011 11:30 am
MrRocky wrote:
ah crap
:lol: :lol: yep....
Post Posted: Fri Mar 04, 2011 9:55 pm
pulled tank out filter is discolored with rust/red dirt
tank is full of red grit can figure out if it is rust or red dirt or both
gunna take me ages to clean that sucka and the little clip that holds the filter on flew off and has disappeared.
c'mon suzistore fingers crossed they got one in stock :(
Post Posted: Fri Mar 04, 2011 10:27 pm
inside the tank
just filled up with 98 - spewin
i just want to drive it :evil:
Post Posted: Fri Mar 04, 2011 10:48 pm
that fuel looks like it was made by the refinery in Mad Max2
Post Posted: Fri Mar 04, 2011 11:04 pm
Is that 4wd??
Post Posted: Sat Mar 05, 2011 1:48 am
AWD
and all fixed :D time to get bogged
Post Posted: Sat Mar 05, 2011 1:58 am
AWESOME!
so will you come on the next AZ run? =P
Post Posted: Sat Mar 05, 2011 2:02 am
alien wrote:
AWESOME!
Armsup
Post Posted: Sat Mar 05, 2011 2:47 am
MrRocky wrote:
AWD
Thay are crazy fun in the wet... :lol:
Post Posted: Sat Mar 05, 2011 3:33 am
Post Posted: Sat Mar 05, 2011 3:48 am
heading up to lancelin on monday morning to test her out, but it will be a strictly no rocks affair for this rig as panels and parts are impossible.
pompoms
Users browsing this forum: Google [Bot] and 308 guests
